Flattening aluminium hbp November 16, 2015 11:54AM |
Re: Flattening aluminium hbp November 16, 2015 12:05PM |
Re: Flattening aluminium hbp November 16, 2015 11:35PM |
Re: Flattening aluminium hbp November 18, 2015 02:16AM |
Re: Flattening aluminium hbp November 18, 2015 03:31AM |
ekaggrat
if the bend is not so much you can sand it down using a course sandpaper attached to a block. then mount 4 mm glass ( 2mm will bend ) on top of it using silicone thermal pads to take care of the rest of the bumps remaining.
Re: Flattening aluminium hbp November 18, 2015 04:03PM |
etfrench
A block of wood will probably not be flat enough. A granite tile might be, but check it first. This video has a good explanation of the lapping process: [www.youtube.com]
ekaggrat
Re: Flattening aluminium hbp November 19, 2015 11:52AM |
ekaggrat
Re: Flattening aluminium hbp November 19, 2015 01:34PM |
