Which one is stronger ?
November 19, 2015 05:02PM
Guys,
I want to print a part,
Which one is stronger between nylon and carbon reinforced PLA ?
What's the positive and negative side between of two ?
Thanks
Re: Which one is stronger ?
November 20, 2015 07:40AM
Search youtube for Tom sanders' video
He made an extensive rest on material strength
November 20, 2015 07:49AM
Hi guys,
I don't find any Tom Sanders video about 3d printing on youtube.
Are you refering to Thomas Salanderer plastic destruction test ?
As far as I remember it was about PLA vs ABS vs Bridge.
++JM
November 20, 2015 08:37PM
Lol
Yes yes, that is the gentleman!!
My bad!!
November 21, 2015 03:31AM
What kind of "strongest"? Depending on the use, I would say, either one.
November 21, 2015 05:15AM
do you reckon carbon inforced PLA is strong enough for a functional component ? for example a bicycle pedal ?...
thanks
November 22, 2015 02:34AM
bianchi
thanks
I don't no enough on the subject to make a guess. Do the pedal have a shaft or is it self supporting?
November 22, 2015 06:06AM
Yes it has a shaft, a normal bicycle pedal...
November 22, 2015 02:25PM
Then I would guess it is possible but it will depend very much on the design being right for the material.
November 22, 2015 03:54PM
Hi guys,
Nylon is a resistant material, but it's soft an flex easily.
Taulman's Bridge is a Nylon composite and is more rigid.
I haven't try carbon reinforced PLA, I dunno if it's realy strong or not.
For a standard bike pedal I would use quality ABS with at last 50% infill, it should be strong enough.
++JM
November 23, 2015 04:39AM
Check out Tech2's vids, he tests Nylon Alloy 910.
