Is it shrinking by itself ?
Posted by bianchi
November 26, 2015 04:35PM
Guys,
I tried to print some objects, but in one corner, it supposed to be flat, but when I finished printing, that corner was a bit bending up, not flat to Z = 0, why was it ?
Was it because of PLA shrinking ?
Thanks
Re: Is it shrinking by itself ?
November 26, 2015 08:26PM
This sounds like the plastic became detached as it was printing, causing the corner to curl up.
PLA does shrink, but if you have good bed adhesion, the corners should be able to overcome this problem.
Check that your adhesion method of choice is applied well (painters tape, hairspray, glue, etc) and try again.
I have found that hairspray on a warm bed (~50 degrees) works very well for me.
November 26, 2015 09:04PM
I use buildtak and not putting anything else on top...can I clean it first with alcohol?
November 27, 2015 01:32PM
bianchi
I use BuildTak too, you should clean it with alcohol, good and often. it is sensitive to grease and dirt.
