This sounds like the plastic became detached as it was printing, causing the corner to curl up.
PLA does shrink, but if you have good bed adhesion, the corners should be able to overcome this problem.
Check that your adhesion method of choice is applied well (painters tape, hairspray, glue, etc) and try again.
I have found that hairspray on a warm bed (~50 degrees) works very well for me.
