X end stop doesn't work [Ramps 1.4 + Arduino Mega 2560, Marlin] December 04, 2015 02:38PM |
Re: X end stop doesn't work [Ramps 1.4 + Arduino Mega 2560, Marlin] December 05, 2015 03:39AM |
Re: X end stop doesn't work [Ramps 1.4 + Arduino Mega 2560, Marlin] December 05, 2015 05:46AM |
Re: X end stop doesn't work [Ramps 1.4 + Arduino Mega 2560, Marlin] December 06, 2015 04:51AM |
Re: X end stop doesn't work [Ramps 1.4 + Arduino Mega 2560, Marlin] December 06, 2015 05:42AM |
Re: X end stop doesn't work [Ramps 1.4 + Arduino Mega 2560, Marlin] December 07, 2015 03:01PM |
#ifndef PINS_H
#define PINS_H
#define X_MS1_PIN -1
#define X_MS2_PIN -1
#define X_MS3_PIN -1
#define Y_MS1_PIN -1
#define Y_MS2_PIN -1
#define Y_MS3_PIN -1
#define Z_MS1_PIN -1
#define Z_MS2_PIN -1
#define Z_MS3_PIN -1
#define DIGIPOTSS_PIN -1
* Arduino Mega pin assignment
#if MOTHERBOARD == 33
#define KNOWN_BOARD 1
#ifndef __AVR_ATmega1280__
#ifndef __AVR_ATmega2560__
#error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
#endif
#endif
#define LARGE_FLASH true
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#define X_MIN_PIN 2
#define X_MAX_PIN 3
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#define Y_MIN_PIN 14
#define Y_MAX_PIN 15
#define Z_STEP_PIN 46
#define Z_DIR_PIN 48
#define Z_ENABLE_PIN 62
#define Z_MIN_PIN 18
#define Z_MAX_PIN 19
#define SDPOWER -1
#define SDSS 53
#define LED_PIN 13
#define PS_ON_PIN 12
#if defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL)
#define KILL_PIN 41
#else
#define KILL_PIN -1
#endif
#ifdef ULTRA_LCD
#ifdef NEWPANEL
#define LCD_PINS_RS 16
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 23
#define LCD_PINS_D5 25
#define LCD_PINS_D6 27
#define LCD_PINS_D7 29
#ifdef REPRAP_DISCOUNT_SMART_CONTROLLER
#define BEEPER 37
#define BTN_EN1 31
#define BTN_EN2 33
#define BTN_ENC 35
#define SDCARDDETECT 49
#elif defined(LCD_I2C_PANELOLU2)
#define BTN_EN1 47 //reverse if the encoder turns the wrong way.
#define BTN_EN2 43
#define BTN_ENC 32
#define SDSS 53
#define SDCARDDETECT -1
#define KILL_PIN 41
#elif defined(LCD_I2C_VIKI)
#define BTN_EN1 22 //reverse if the encoder turns the wrong way.
#define BTN_EN2 7
#define BTN_ENC -1
#define SDSS 53
#else
//arduino pin which triggers an piezzo beeper
#define BEEPER 33 // Beeper on AUX-4
//buttons are directly attached using AUX-2
#ifdef REPRAPWORLD_KEYPAD
#define BTN_EN1 64 // encoder
#define BTN_EN2 59 // encoder
#define BTN_ENC 63 // enter button
#define SHIFT_OUT 40 // shift register
#define SHIFT_CLK 44 // shift register
#define SHIFT_LD 42 // shift register
#else
#define BTN_EN1 37
#define BTN_EN2 35
#define BTN_ENC 31 //the click
#endif
#ifdef G3D_PANEL
#else
#define SDCARDDETECT -1 // Ramps does not use this port
#endif
#endif
#else //old style panel with shift register
//arduino pin witch triggers an piezzo beeper
#define BEEPER 33 //No Beeper added
//buttons are attached to a shift register
// Not wired this yet
//#define SHIFT_CLK 38
//#define SHIFT_LD 42
//#define SHIFT_OUT 40
//#define SHIFT_EN 17
#endif
#endif //ULTRA_LCD
#else // RAMPS_V_1_1 or RAMPS_V_1_2 as default (MOTHERBOARD == 3)
#endif
// SPI for Max6675 Thermocouple
#ifndef SDSUPPORT
// these pins are defined in the SD library if building with SD support
#define MAX_SCK_PIN 52
#define MAX_MISO_PIN 50
#define MAX_MOSI_PIN 51
#define MAX6675_SS 53
#else
#define MAX6675_SS 49
#endif
#endif //MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34 || MOTHERBOARD == 35 || MOTHERBOARD == 77
#ifndef KNOWN_BOARD
#error Unknown MOTHERBOARD value in configuration.h
#endif
//List of pins which to ignore when asked to change by gcode, 0 and 1 are RX and TX, do not mess with those!
#ifdef X_STOP_PIN
#if X_HOME_DIR < 0
#define X_MIN_PIN X_STOP_PIN
#define X_MAX_PIN -1
#else
#define X_MIN_PIN -1
#define X_MAX_PIN X_STOP_PIN
#endif
#endif
#ifdef Y_STOP_PIN
#if Y_HOME_DIR < 0
#define Y_MIN_PIN Y_STOP_PIN
#define Y_MAX_PIN -1
#else
#define Y_MIN_PIN -1
#define Y_MAX_PIN Y_STOP_PIN
#endif
#endif
#ifdef Z_STOP_PIN
#if Z_HOME_DIR < 0
#define Z_MIN_PIN Z_STOP_PIN
#define Z_MAX_PIN -1
#else
#define Z_MIN_PIN -1
#define Z_MAX_PIN Z_STOP_PIN
#endif
#endif
#ifdef DISABLE_MAX_ENDSTOPS
#endif
#ifdef DISABLE_MIN_ENDSTOPS
#endif
#define SENSITIVE_PINS {0, 1, X_STEP_PIN, X_DIR_PIN, X_ENABLE_PIN, X_MIN_PIN, X_MAX_PIN, Y_STEP_PIN, Y_DIR_PIN, Y_ENABLE_PIN, Y_MIN_PIN, Y_MAX_PIN, Z_STEP_PIN, Z_DIR_PIN, Z_ENABLE_PIN, Z_MIN_PIN, Z_MAX_PIN, PS_ON_PIN, \
#endif
