Using Reprap Technology To Make a Low Cost Wood Machining CNC
Posted by NoelM
September 13, 2010 05:38PM
Hi Everyone,
I am entirely new to Reprapping, and was wondering if anyone could comment on trying to use the RepRap model to build a low cost wood machining CNC? Obviously the construction would have to be strengthened to deal with the increased stress, and the motors would have to be upgraded to deal with the increased weight ... but can anyone tell me if this is worth pursuing, or should I just shut down the idea right away?
Thanks
Re: Using Reprap Technology To Make a Low Cost Wood Machining CNC
September 13, 2010 05:57PM
The belts would also have to be replaced with either really wide and thick ones, a screw, or a rack-and-pinion. The hobby CNC router people are moving to rack-and-pinion. Right now it's cheaper, faster, and just as accurate as screws. We wish we had used rack-and-pinion on our router.
September 13, 2010 06:02PM
Take a look at Mantis 9.1:
[makeyourbot.org]
It uses drive screws instead of belts for more torque and slower speeds. It looks easy enough to bootstrap too, although I have not found the electronics package yet.
The vids he's produced seem to be kit-centric, (he seens to have sent out kits at some point), but there are dfx file available. Now If I could only learn enough of qcad to extract the measurements myself.
September 13, 2010 06:27PM
if you're using belts you might need to use nema23 motors.
not sure how easy it is to get GEN3 electronics to work with EMC2, or how easy it is to use the reprap host software to drive a CNC for milling purposes. most probably all possible just not documented.
September 13, 2010 07:36PM
That is hard to imagine. I think a ball screw will always have more resolution, less backlash and be stiffer. They are slower and more costly than a rack of course.
September 13, 2010 11:33PM
Hi Everyone,
Thanks
Hmmm ...
Vanilla Mendel, no.
http://reprap.org/wiki/Eiffel
is in theory adaptable to that. smiling bouncing smiley
(pst: Todd. Eiffel = good new thing to sell, eventually.)
http://reprap.org/wiki/ORE-Bot
would work, but I bet the build volume is too small for your needs.
Better off to use http://reprap.org/wiki/EMCRepRap
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
