"printing" in a loop? December 08, 2015 11:42AM |
Re: "printing" in a loop? December 08, 2015 01:24PM |
Re: "printing" in a loop? December 08, 2015 01:47PM |
Admin Registered: 18 years ago Posts: 14,157 |
Re: "printing" in a loop? December 08, 2015 04:05PM |
Re: "printing" in a loop? December 08, 2015 06:36PM |
Re: "printing" in a loop? December 08, 2015 07:08PM |
Re: "printing" in a loop? December 09, 2015 05:05AM |
Re: "printing" in a loop? December 09, 2015 05:58PM |
Re: "printing" in a loop? December 09, 2015 06:47PM |
long belts, but you wouldn't be able to etch right to the ends. I guess the workflow would be to cut the belt to the right width, etch it, cut off the unetched ends, then add buckle and holes.
Re: "printing" in a loop? December 10, 2015 04:00AM |
frankvdh
No need for a drum, though. You could just have some kind of "extruder" (a gear that's driven by a stepper motor, and a clamp wheel to press the belt against the gear) mechanism to move the belt. You would probably also need a couple of guides to keep the belt aligned.
This would work with infinitelylong belts, but you wouldn't be able to etch right to the ends. I guess the workflow would be to cut the belt to the right width, etch it, cut off the unetched ends, then add buckle and holes.
Re: "printing" in a loop? December 10, 2015 04:05AM |
elwood127
Your leather belt would wrap around the drum. The belt inside the drum is a GT-2 for driving the Y axis.
[attachment 67326 DrumandXCarriage.jpg]
Re: "printing" in a loop? December 10, 2015 05:37PM |
Re: "printing" in a loop? December 15, 2015 08:09PM |
Re: "printing" in a loop? December 16, 2015 04:09AM |
Re: "printing" in a loop? December 17, 2015 04:09PM |
