Hello,
I'm trying to put together a BOM and cost of items for a reprap, but I get the following error when trying to import the BOM to amazon using the link on parts.reprap.org. Anyone know how to fix it?
Thanks,
Mike
Warning: file_get_contents() [function.file-get-contents]: URL file-access is disabled in the server configuration in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 64
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartCreate&Item.0.ASIN=0071459332&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 64
Warning: file_get_contents() [function.file-get-contents]: URL file-access is disabled in the server configuration in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 72
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartClear&CartId=&HMAC=) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 72
Warning: file_get_contents() [function.file-get-contents]: URL file-access is disabled in the server configuration in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000FN0E4Y&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000FMWW4U&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OD1THG&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000Q5UN7E&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OD1TSA&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000NBKLHS&Item.0.Quantity=2) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000FN160A&Item.0.Quantity=2) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OCUU8G&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OD1QD8&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OD1QGU&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OD0AGW&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OCW3ZE&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000OD0AOY&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000NHXKUC&Item.0.Quantity=2) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000NBGGFY&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000FMWW9U&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B00066ISVG&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B000S5FAF2&Item.0.Quantity=1) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartAdd&CartId=&HMAC=&Item.0.ASIN=B00065VD46&Item.0.Quantity=8) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 84
Warning: file_get_contents() [function.file-get-contents]: URL file-access is disabled in the server configuration in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 94
Warning: file_get_contents(http://ecs.amazonaws.com/onca/xml?Service=AWSECommerceService&AWSAccessKeyId=&AssociateTag=reprresefoun-20&Operation=CartGet&CartId=&HMAC=) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /home/.obession/reprap_parts/parts/controllers/supplier.php on line 94
* Home
* About
* Parts
* Suppliers
* Statistics
* Store
* RepRap.org
RepRap Parts Lister
RepRap Parts Lister
Your Amazon Cart
Errors:
* Error adding B000FN0E4Y to cart.
* Error adding B000FMWW4U to cart.
* Error adding B000OD1THG to cart.
* Error adding B000Q5UN7E to cart.
* Error adding B000OD1TSA to cart.
* Error adding B000NBKLHS to cart.
* Error adding B000FN160A to cart.
* Error adding B000OCUU8G to cart.
* Error adding B000OD1QD8 to cart.
* Error adding B000OD1QGU to cart.
* Error adding B000OD0AGW to cart.
* Error adding B000OCW3ZE to cart.
* Error adding B000OD0AOY to cart.
* Error adding B000NHXKUC to cart.
* Error adding B000NBGGFY to cart.
* Error adding B000FMWW9U to cart.
* Error adding B00066ISVG to cart.
* Error adding B000S5FAF2 to cart.
* Error adding B00065VD46 to cart.
Warning: Invalid argument supplied for foreach() in /home/.obession/reprap_parts/parts/views/supplier.amazon_checkout.php on line 19
Item Qty Price Total
Total:
(If that doesn't work, click here)
Copyright 2007 RepRap. All code and data licensed under GNU GPL
