Extruder Runs In Reverse on Newly Completed Aurora Z-605S
December 24, 2015 10:37AM
I just completed assembling my new Aurora Z-605S purchased from Gear Best. When I use the Move Axis feature under Prepare on the LCD, the extruder runs in reverse; negative motion feeds filament. All of the cables and connectors are plugged and appear to be the correct orientation. Has anyone else seen this? What wiring configuration should I check? Thanks!
Re: Extruder Runs In Reverse on Newly Completed Aurora Z-605S
December 24, 2015 10:40AM
I failed to mention that the other axis motors appear to move in the correct direction.
December 24, 2015 07:11PM
If the system is using Marlin, just change the following line in configuration.h
#define INVERT_E0_DIR false
(if it is true change to false, etc.)
Or, just flip the stepper motor plug.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
December 24, 2015 09:03PM
Thanks. I swapped the A - and + wires. Working fine. Now I need to get all the calibration correct.
