Best 3D Modeling Software January 13, 2016 09:32PM |
Re: Best 3D Modeling Software January 13, 2016 10:00PM |
Re: Best 3D Modeling Software January 13, 2016 10:27PM |
Re: Best 3D Modeling Software January 13, 2016 10:36PM |
Re: Best 3D Modeling Software January 13, 2016 11:11PM |
Re: Best 3D Modeling Software January 14, 2016 10:45AM |
Re: Best 3D Modeling Software January 14, 2016 01:16PM |
Re: Best 3D Modeling Software January 14, 2016 02:38PM |
gmh39
You can probably get around the storage limits but exporting your parts, saving locally, then importing next time you use them next time you need to use them. a bit convoluted, but with a USB drive, you can take the files to any computer.
Re: Best 3D Modeling Software January 14, 2016 02:40PM |
Re: Best 3D Modeling Software January 15, 2016 05:44PM |
the_digital_dentist
"One to avoid: Sketchup".
Re: Best 3D Modeling Software January 15, 2016 10:03PM |
plankton
the_digital_dentist
Disagree with that, Sketchup was by far the easiest to get started with (after trying several of the other free options), and is really intuitive (most the time) and easy to use.
I do understand what you mean about the holes, however there is a very simple solution to that, just design everything at 10x scale (the holes only ever happen at very small scales), it takes 2 seconds to rescale the model before I finally convert it to an STL.
Re: Best 3D Modeling Software January 15, 2016 11:43PM |
plankton
Re: Best 3D Modeling Software January 16, 2016 09:15AM |
the_digital_dentist
Unfortunately, there isn't any CAD with a good UI for linux (but you can use OnShape). Right about now a bunch of guys who use FreeCAD are turning red and getting ready to burn me to the ground for saying that, but FreeCAD is an open source project by a bunch of different people with a bunch of different ideas about how CAD should work and it's a bit of a mess.
Re: Best 3D Modeling Software January 16, 2016 09:54AM |
Re: Best 3D Modeling Software January 16, 2016 11:04AM |
the_digital_dentist
plankton
The fact that you have to load a special plug-in to get STL export capability tells you that Sketchup is not intended for designing things with accurate/precise size/fit. If you need tricks and work-arounds for the most basic function of the software, the software sucks. Scaling things up doesn't change the fact that curves are represented as polygons. Sketchup is great for some things, but not for 3D printing.
If you like Sketchup, you'll love DSM. It has a similar UI and learning curve, but none of the problems and many more capabilities/features, with no work-arounds or special tricks required.
Re: Best 3D Modeling Software January 16, 2016 11:24AM |
Re: Best 3D Modeling Software January 16, 2016 11:26AM |
Re: Best 3D Modeling Software January 16, 2016 01:21PM |
Re: Best 3D Modeling Software January 16, 2016 02:28PM |
Re: Best 3D Modeling Software January 16, 2016 02:58PM |
the_digital_dentist
.... It just isn't good CAD software for 3D printing.
Re: Best 3D Modeling Software January 16, 2016 04:52PM |
Re: Best 3D Modeling Software January 16, 2016 06:07PM |
Re: Best 3D Modeling Software January 16, 2016 08:45PM |
Re: Best 3D Modeling Software January 16, 2016 10:14PM |
Re: Best 3D Modeling Software January 16, 2016 10:21PM |
Re: Best 3D Modeling Software January 17, 2016 01:38PM |
Re: Best 3D Modeling Software January 24, 2016 02:07AM |
Re: Best 3D Modeling Software January 24, 2016 02:20AM |
Re: Best 3D Modeling Software January 29, 2016 11:21AM |
