Bowden quick disconnect type January 18, 2016 06:26PM |
Re: Bowden quick disconnect type January 18, 2016 08:08PM |
Re: Bowden quick disconnect type January 19, 2016 03:19AM |
Re: Bowden quick disconnect type January 19, 2016 11:32AM |
Re: Bowden quick disconnect type January 19, 2016 12:54PM |
Giantkiller
Yep. I installed an R/O water filtering system and used the nylon versions of these.
I just have to design a Thingy interface to house the female part then put that thingy on the extruder thingy.
I am overthinged.
Re: Bowden quick disconnect type January 19, 2016 12:59PM |
Re: Bowden quick disconnect type January 19, 2016 01:03PM |
Re: Bowden quick disconnect type January 19, 2016 01:25PM |
Re: Bowden quick disconnect type January 19, 2016 01:30PM |
Giantkiller
Oh yeah. I pulled that down and am working my interation right now.
Re: Bowden quick disconnect type January 19, 2016 04:34PM |
Re: Bowden quick disconnect type January 19, 2016 06:25PM |
Re: Bowden quick disconnect type January 19, 2016 09:20PM |
Re: Bowden quick disconnect type January 20, 2016 02:24AM |
Giantkiller
I hope this is on track. The pressure fitting enables the tube to slide without deforming the inside diameter of the tube. There are reprap instructions to use a 2mm drill bit to ream the tube once it has been screwed on the initial fitting. I believe part of your concern deals with part of this issue in this way.
We all know variations appear in products due to a previous mechanical failure point.
Re: Bowden quick disconnect type January 20, 2016 03:23AM |
dougal1957
I think what he means is that on some of the fittings the internal bore is at least 4mm all the way thru so you can pass the PTFE tube all the way thru the fitting which is a good idea and I drill all mine out at the back to allow this to happen, Minimum thread size to do this is M6. The riprap instructions are for there own design which is not the same as these push fit fittings at all.
Re: Bowden quick disconnect type January 20, 2016 11:58PM |
Re: Bowden quick disconnect type January 21, 2016 02:51PM |
Re: Bowden quick disconnect type January 23, 2016 04:38PM |
