Bed suddenly stoped heating.
Posted by doser_fu
January 31, 2016 07:43AM
Hi, i was ready to print, everything was ok but when "Bed heating" it didnt heat up, the led in ramps does not light up... thermistor seems ok.... now im testing in proterface and the led does not light up.
I got some temperature errors in the past when not totally cooled down and i ordered to reheat, only 2 times... (just in case it matters)
thanks for your help! winking smiley
Re: Bed suddenly stoped heating.
January 31, 2016 08:30AM
Check your connections to heated bed.
Ensure that the wires upon the thermistor are not touching together or any metal parts near the hot end?
Check Do you have 12V at the bed connections when you request to turn on the heat bed in proterface?
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
January 31, 2016 11:23AM
The thermistor wires can cause mystery problems. If there is a bare spot in the covering this can intermittently touch the heater block.
January 31, 2016 12:27PM
It came back, i checked my wires and it was all ok, now its gone again... thermistor reads ok, but this will not heat up (red led will not turn on)
12v are reaching, hotend and fan work ok... no idea what is happening... :/
January 31, 2016 12:50PM
doser_fu
Is there 12v at the heated bed connections?
Check the pins inside the connector housings, are they tight?
February 01, 2016 05:14AM
yep, all wiring is ok, i had another ramps, tried and works perfectly.... d8 mosfet dead? :/
thanks!
February 04, 2016 01:19PM
hey there looks liek you got the same kit as me my gt board had a short at the micro fuse the heat bead would only turn on if i tapped it then this happened
might wanna watch that i've since taken the fuse holder out and bridged it
February 04, 2016 03:06PM
Was the fuse shorted or was it spec'd to large for the intended use. Not all fuses are "fast".
February 04, 2016 03:26PM
Apparently that socket is not rated for 15amp.. several have reported that the fuse was fine, but the holder caught on fire!
