Wipe nozzle via GCODE February 02, 2016 08:33PM |
;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops M117 Auto-level... G29 ;auto-level ;G92 Z-.01 ; Lower = Z Pos, Lift = Z Neg M117 Preparing... G1 Z10.0 F{travel_speed} ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F100 E30 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M300 S900 P160 ;start beep M300 S1000 P160 M300 S2000 P160 M0 ;Wait for the user M117 Printing...
Re: Wipe nozzle via GCODE February 02, 2016 10:22PM |
Re: Wipe nozzle via GCODE February 03, 2016 07:31AM |
Re: Wipe nozzle via GCODE February 03, 2016 07:42AM |
Re: Wipe nozzle via GCODE February 03, 2016 02:39PM |
