Bed Leveling but extruder head out of bounds
February 17, 2016 04:35PM
I'm trying to level the bed and print but it goes auto home and out of bounds confused smiley
Me trying to level my bed
Re: Bed Leveling but extruder head out of bounds
February 17, 2016 04:42PM
Just jog the axis manually and level.
I had nothing but issues with that tool on my i3 also.
February 17, 2016 04:57PM
Thanks for the quick reply. I did so manually before I was able to connect my i3 to Cura. I just wanted to try it again with the leveling wizard to make sure. It also tried to print a large square but it the head was too close and the PLA didn't stick. I then noticed I have a problem with the extruder head not zeroing out on the bed.
When I auto home the coordinates are -5, -55, .8
The Z axis is the only one that goes to the right place. The X axis is too far to the left and the Y axis is really far back
February 18, 2016 11:49AM
Got it going with Pronterface thanks you smiling smiley ...now I have this issue...
Edited 1 time(s). Last edit at 02/18/2016 12:01PM by nguill00.
open | download - 12746325_10156561055155182_1059223539_n.jpg (33.5 KB)
February 18, 2016 01:52PM
Without knowing the shape of what you are trying to print its just a guess but i'm going to say maybe you are going too fast on the first layer for it to stick, or the bed still is not level.
I print my first layer in ABS at 10mm/sec to get good contact.
February 18, 2016 04:21PM
Also, don't overlap the tape. Put the edges up against each other.
February 18, 2016 04:29PM
Ok. I will make sure to fix that. And I am using PLA. So do I change the speed settings on the printer itself or would it be on Pronterface? I am pretty sure it's level all the sides measure the same.
open | download - test print.png (140.5 KB)
February 19, 2016 12:19AM
Change the first layer speed in Cura.
Its under "advanced" and listed as bottom layer speed. 10-20 works good. nice and slow on the first layer.
Print stepping on y axis every time it goes up a layer
February 22, 2016 03:20PM
How do I fix this?
open | download - Screenshot - 02222016 - 02:12:09 PM.png (84.1 KB)
open | download - 12729198_10156575917365182_3116149723678434380_n.jpg (56.8 KB)
February 24, 2016 11:28AM
Make sure the pulleys aren't slipping on the motor shaft for X and Y, you may find one slipping. Tighten the grub screw.
Make sure the belts are tight, not too tight.
With the printer powered off, try to move the X and Y carriages by hand. They should slide smoothly and easily.
