12v/30 amp car relay+1n4148 diode? February 21, 2016 01:21AM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 01:30AM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 02:35AM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 02:51AM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 01:06PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 01:10PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 01:18PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 01:38PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 02:48PM |
), and I ended up installing a mosfet used in this tutorial: [hassanulmakers.wordpress.com].|
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 03:25PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 03:51PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 04:01PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 04:10PM |
mato84
With all the noise the printer makes, I don´t mind the clicking very much. What do you mean I don´t need the diode?
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 04:17PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 07:30PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 09:12PM |
Re: 12v/30 amp car relay+1n4148 diode? February 21, 2016 10:15PM |
the_digital_dentist
Some automotive relays have shunt rectifiers built in- if the relay has a polarity marking that may be why. Check the relay's spec sheet.
the_digital_dentist
I'd probably look for a diode that's intended to be used as a rectifier in a power supply, not a small signal switching diode like the 1N4148.
Re: 12v/30 amp car relay+1n4148 diode? February 22, 2016 12:45AM |
Re: 12v/30 amp car relay+1n4148 diode? February 22, 2016 01:13AM |
Re: 12v/30 amp car relay+1n4148 diode? February 22, 2016 02:22AM |
Re: 12v/30 amp car relay+1n4148 diode? February 22, 2016 10:06PM |
Re: 12v/30 amp car relay+1n4148 diode? February 23, 2016 07:13AM |
