Re: An alternative to printed parts? July 19, 2018 12:32PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: An alternative to printed parts? July 19, 2018 02:14PM |
Assuming that this is a rhetorical question rather than a dismissal of the project. To me RepRap became important when I built my frist 3D printer (A Prusa Mendel) and was able to get the occasionla print which was more accurate and better finished than the Stratasys printer used by the design consultancy that then employed me. That my printer used salvaged parts and cost a few hundred pounds instead of the £75,000 that the Stratasys cost made it very important.Quote
cwaa
When did RepRap become so important? ........
Simplistic ideas about the importance of rigidity without a measure of the forces that are involved and thoughts about the suitability of one material over another do nothing for me. The Pyramid builders went for rigidity but when people started thinking about structure they were able to build cathedrals and then skyscrapers. In the future there may even be space elevators - built largely out of plastic.Quote
I started in 3d printing 3 years ago and didn't use anything from Rep Rap. How is that possible? Well I researched 3d printing for a while and learned a lesson in rigidity. Making frames with plastic joints is not going to make a quality printer......
I can print; My printers do not need constant calibration; I do want to experiment and play (and perhaps make some meaningful contribution to the knowledge base)Quote
You may be able to print, but it will be a toy needing constant calibration. So if you want to experiment and play with RepRap designs go ahead.
If your objective is purely to build a high quality printer then build it by specifying what you want and getting 3D Systems or ExOne [investingnews.com] to do the laborious bit of the job. Trust me, I don't mean to be insulting by this but it will be a better quality printer than you have made. Most people have a budget to work to and the best results can be obtained by good engineering, often withe a lower financial cost.Quote
I wanted to build a high quality printer that would be stable and not require high levels of maintenance. I got my materials from Openbuilds and used Smoothieware. So if your objective is a high quality printer, you have to put the RepRap slogan away.
I don't recall anybody implying that you do not belong here or any loose chat of banishment. You do however have to get used to the fact that the members often won't agree with you.Quote
If that means I don't belong here, fine with me. You can ban me, but the slogan is still not reasonable unless you want to play with toys!
Re: An alternative to printed parts? July 19, 2018 02:40PM |
Re: An alternative to printed parts? July 19, 2018 03:39PM |
Re: An alternative to printed parts? July 19, 2018 04:51PM |
An opinion seemingly unsupported by anything other than that it is your opinion. Kinda makes me wonder (without wishing to put pressure one way or another) just why you are on the RepRap forum. You don't appear, or won't admit, to having learned anything here; neither does contributing anything seem to be something you would willingly do.Quote
cwaa
.................................................... I don't really give a shit who agrees with me.....I still have my opinion..........................
Re: An alternative to printed parts? July 19, 2018 05:12PM |
Re: An alternative to printed parts? July 19, 2018 09:16PM |
cwaa
When did RepRap become so important? I started in 3d printing 3 years ago and didn't use anything from Rep Rap. How is that possible? Well I researched 3d printing for a while and learned a lesson in rigidity. Making frames with plastic joints is not going to make a quality printer. You may be able to print, but it will be a toy needing constant calibration. So if you want to experiment and play with RepRap designs go ahead. I wanted to build a high quality printer that would be stable and not require high levels of maintenance. I got my materials from Openbuilds and used Smoothieware. So if your objective is a high quality printer, you have to put the RepRap slogan away. If that means I don't belong here, fine with me. You can ban me, but the slogan is still not reasonable unless you want to play with toys!
Re: An alternative to printed parts? July 20, 2018 03:05AM |
dlc60
(Side thought) I am hoping that we will eventually move past the 8-bit Arduino. But I really want the idea behind the Arduino to stay. Something that can be programmed by anyone without special closed source tools. RepRap and Arduino came from different directions to enable 3D printers "for the masses". What will the next cool (and unrelated) thing be that boosts us past our current development plateu?
Re: An alternative to printed parts? July 20, 2018 04:41AM |
Re: An alternative to printed parts? July 20, 2018 08:42AM |
Re: An alternative to printed parts? July 20, 2018 09:05AM |
Re: An alternative to printed parts? July 20, 2018 10:21AM |
Re: An alternative to printed parts? July 20, 2018 10:38AM |
Re: An alternative to printed parts? July 20, 2018 11:18AM |
Re: An alternative to printed parts? July 20, 2018 12:40PM |
Re: An alternative to printed parts? July 20, 2018 12:57PM |
VDX
... life is a game - with many "toys" to play through it
Re: An alternative to printed parts? July 20, 2018 05:39PM |
cwaa
cwaa
Now I have a workhorse cartesian and a very stout Delta
Re: An alternative to printed parts? July 21, 2018 08:43PM |
leadinglights
I tried to resist commenting on both of these things but have failed
Opinion on the meaning of the word "toy" may vary.
- I have seen deckingman's printer at the TCT show and it was better made and printed better than most of the 3D printers on commercial printer stands. .
- Linux is the operating system used on ALL (as in every last one) of the top 200 supercomputers
Mike
Re: An alternative to printed parts? July 22, 2018 04:46AM |
Re: An alternative to printed parts? November 24, 2019 04:29PM |
