y-axis move noise
Posted by bw_syl
y-axis move noise
April 05, 2016 09:36AM
Hello,
I've build a prusa i3 and I have noises on some y-axis moves you can hear it there : y-move noise video
Is this normal noise ? What could I do to avoid this ?
Thanks a lot.
bw_syl
Re: y-axis move noise
April 05, 2016 01:36PM
Maybe the stepper driver is applying too much voltage, this is a reason for noisy operation. Acceleration and jerk settings could also be a reason.
April 08, 2016 10:37AM
do you have microstepping enabled? i ran my printer with 0 microstepping for a little while and it was really loud
April 08, 2016 12:23PM
What sort of bearings and how many of them are there attached to the undercarriage?
It sounds like slop in the bearings is allowing the undercarriage to rattle.
April 08, 2016 02:54PM
Mine does the same thing. Its the cheap LM8UU bearings rattling on the rods.
Anonymous User
April 09, 2016 05:40AM
Nothing to be surprised !
The LM bearings are most probably OK but NOT the rods ! Most suppliers send regular SS rods which are not g6, h6 class. You have to replace them with proper hardened steel rods designed for.
I did that on my Geetech, plus made a pair a bearing holders for one rod to give some tension with some flexibility to avoid binding and therefore marring the ball/rod. Two rods plus two set of bearing means the system is overconstrained and as the frame is not really rigid you can't have a perfect alignment of the rods that will last.
On X and Z as they are most probably under tension, therefore less play thus less noise.
Now the only annoying noise is the power supply fan.
Edited 1 time(s). Last edit at 04/10/2016 10:44AM by MKSA.
