Support Question
April 11, 2016 07:17PM
Hey all, using support in Slic3r 1.2.9 is creating support on the outside of a flat surface where no support is needed. Also, setting the "Enforce Support For" X layers (60 in this case) still produces support all the way to the top. Assuming that Enforce Support means "only build supports for 60 layers". Anyone know how to correct these issues? Thanks.
Re: Support Question
April 11, 2016 09:11PM
You might have better luck in the slic3r section of the forum
[forums.reprap.org]
But I would guess there are faults in the model causing tiny holes which the support is trying to support the top of.
Is the model public? can you share the url?
Edited 2 time(s). Last edit at 04/11/2016 09:37PM by Dust.
April 11, 2016 10:05PM
The support up the side is how it gets into position to support the top surface of the through holes. It's usually a pain to remove. For functional parts I generally prefer to print without support and rely on bridging. There's usually some clean-up needed, but it's often easier than trying to remove the support. And it's much quicker to print without support.
Enforce isn't a limiter, it adds more support for the first n layers when support wouldn't normally be needed.
Edited 1 time(s). Last edit at 04/11/2016 10:06PM by JamesK.
April 11, 2016 10:08PM
Thanks guys.
