HICTOP i3 extruder failure - motor or control board? April 13, 2016 01:59PM |
Re: HICTOP i3 extruder failure - motor or control board? April 13, 2016 02:23PM |
Re: HICTOP i3 extruder failure - motor or control board? April 13, 2016 03:49PM |
Re: HICTOP i3 extruder failure - motor or control board? April 15, 2016 09:26PM |
Re: HICTOP i3 extruder failure - motor or control board? April 17, 2016 07:41PM |
Re: HICTOP i3 extruder failure - motor or control board? April 18, 2016 08:41AM |
Re: HICTOP i3 extruder failure - motor or control board? April 18, 2016 08:50AM |
Re: HICTOP i3 extruder failure - motor or control board? April 18, 2016 11:01AM |
JamesK
You can configure the firmware to just use the E1 pins/driver instead of E0, no need to try and fake up dual extruders for that.
// This defines the number of extruders // :[1,2,3,4] #define EXTRUDERS 1 // default
// ORIGINAL: #define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_BED 1 // CHANGE TO: #define TEMP_SENSOR_0 0 // CL: disable E0 thermistor #define TEMP_SENSOR_1 1 // CL: enable E1 thermistor to debug E0 motor/controller #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_BED 1
Re: HICTOP i3 extruder failure - motor or control board? April 18, 2016 11:25AM |
#elif MB(RAMPS_13_EF || MB(RAMPS_13_EE || MB(RAMPS_13_EFF) || MB(RAMPS_13_EEF) #include "pins_RAMPS_13.h"
#define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30
Re: HICTOP i3 extruder failure - motor or control board? April 18, 2016 12:11PM |
Re: HICTOP i3 extruder failure - motor or control board? April 18, 2016 12:18PM |
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 02:03PM |
// CL: swap E0 and E1 outputs to use E1 instead of E0 outputs un-comment below: #define SWAP_E0_WITH_E1 // normal mode = comment out! #ifdef SWAP_E0_WITH_E1 #define E0_STEP_PIN 26 // CL: now assigned to E1 #define E0_DIR_PIN 28 // CL: now assigned to E1 #define E0_ENABLE_PIN 24 // CL: now assigned to E1 #define E1_STEP_PIN 36 // CL: now assigned to E1 #define E1_DIR_PIN 38 // CL: now assigned to E1 #define E1_ENABLE_PIN 30 // CL: now assigned to E1 #else #define E0_STEP_PIN 36 #define E0_DIR_PIN 38 #define E0_ENABLE_PIN 30 #define E1_STEP_PIN 26 #define E1_DIR_PIN 28 #define E1_ENABLE_PIN 24 #endif
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 02:31PM |
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 03:28PM |
/ CL: swap E0 and E1 outputs to use E1 instead of E0 outputs uncomment below: #define SWAP_E0_WITH_E1 // normal mode = comment out! #ifdef SWAP_E0_WITH_E1 #define E0_STEP_PIN 36 // CL: now assigned to E1 #define E0_DIR_PIN 38 // CL: now assigned to E1 #define E0_ENABLE_PIN 30 // CL: now assigned to E1 #define E1_STEP_PIN 26 // CL: now assigned to E0 #define E1_DIR_PIN 28 // CL: now assigned to E0 #define E1_ENABLE_PIN 24 // CL: now assigned to E0 #else #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30 #endif
// For direct drive extruder v9 set to true, for geared extruder set to false. #define INVERT_E0_DIR false #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 05:12PM |
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 06:03PM |
JamesK
Looks like a typo in the new E0 dir pin, the old E1 dir pin was 34, you've got the new EO pin as 38
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 06:10PM |
Question: does the extruder ever feed then appear to retract a little while manually feeding using the LCD-Prepare->Move at 220c and slowly stepping it a 1mm at a time?
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 09:43PM |
#define ENCODER_PULSES_PER_STEP 4 // CL: HICi3 =4, was =1, Increase if you have a high resolution encoder #define ENCODER_STEPS_PER_MENU_ITEM 1 // CL: HICi3 =1, was =5, Set according to ENCODER_PULSES_PER_STEP or your liking
Re: HICTOP i3 extruder failure - motor or control board? April 24, 2016 09:55PM |
