Linear rail weight bearing capacity
May 02, 2016 06:16PM
I am trying to calculate the minimum linear rail sizes that can carry my Y axis and Z axis cars. .The Z axis carries the X axis, so it has two 8 mm rods, a Wade's extruder, a Nema 17 stepper, a plastic X car with four 8 mm bearings, 3 fans and also 2 Z elevators but the weight is practically on the leadscrews, so I don't think a very large rail would be needed (maybe a LM9?). I am not so sure about the Y axis, as it is horizontal and has to carry an aluminum Y car with the MK2 heated bed, an aluminum plate, and a build surface. Would a LM9 be enough? Maybe 12? Could I calculate it with a formula if I knew the weight of the components?
Thanks.
Re: Linear rail weight bearing capacity
May 03, 2016 07:58PM
This site may help with capacities.
[www.pbclinear.com]
May 04, 2016 12:47PM
Look up elastic beam deflections equations. Once you know the mass, length, and area moment of inertia you can find the deflection. You can of course rearrange everything to find the moment of inertia required to meet your deflection tolerance.
May 04, 2016 01:30PM
I can't in good conscience read this thread and not recommend some good linear guides as an alternative to unsupported rods.
May 04, 2016 03:37PM
epicepee
That's exactly why I have posted this. I am trying to choose the right size of linear guides to replace my unsupported rods.
May 05, 2016 04:19PM
drmaestro
epicepee
Ah, sorry, I misunderstood.
Most linear guides are massively overqualified. MGN9 (9mm) rails can take thousands of Newtons, and yet most people use 12mm rails just because they're more available. Find one that looks reputable and cheap and you'llbe fine.
May 05, 2016 10:35PM
Keep in mind that the narrower the rail the more it can flex. In the X carriage anyway.
