Removing a stripped screw on the hot-end May 07, 2016 07:56PM |
Re: Removing a stripped screw on the hot-end May 07, 2016 11:06PM |
Re: Removing a stripped screw on the hot-end May 08, 2016 12:00AM |
Re: Removing a stripped screw on the hot-end May 08, 2016 04:44PM |
Re: Removing a stripped screw on the hot-end May 08, 2016 09:44PM |
Re: Removing a stripped screw on the hot-end May 08, 2016 10:14PM |
hoxsiew
I've found that Torx drivers in a size slightly above that of the hex that is stripped will work very well. The sharp points of the Torx will grab nicely in what's left of the stripped hex. I have a set of Torx drivers down to T3.
Re: Removing a stripped screw on the hot-end May 12, 2016 10:56AM |
