Steppers only move one way.
Posted by Bronston
November 13, 2010 01:53PM
I've been building a mendel for sometime now, finally I scraped together the last bit of money and got all my parts. I've finished pretty much all of the mechanical and electronic construction. I decided to test the axes out and discovered that they will only move forward, when I click the button to move the other direction (both in the reprap software and in repsnapper) they don't move. The lights light up for a split second on the controller but then nothing. I can't figure it out, I've switched the wires around into all possible positions, I think, I've searched the forum and google trying to find someone else who's had this issue. I don't know what the deal is any help would be greatly appreciated.
Thanks
Re: Steppers only move one way.
November 13, 2010 02:58PM
If you are testing it via a firmware and microcontroler for reprap.... understand that without limit switches on the home side, the motors will only turn in the + direction... you can compile the firmware to ignore limit switches.
Al...
[araspitfire.blogspot.com]
November 13, 2010 03:01PM
Ok, I was actually wondering if that had something to do with it as I have yet to install the optos.
Thank you so much for confirming that.
July 22, 2011 10:28AM
For anyone who stumbles on this thread, I had a similar issue where the motors would only move in one direction, but would make weird noises and not turn in the other direction. I am using ReplicatorG and I had incorrectly set the motherboard preferences to the wrong end-stop configuration. It was constantly thinking that it was already at zero.
