So as the subject suggests, its time for a new printer!
If your looking for a printer made from flimsy printed parts and steel rods this page aint for you!
If your after something a little stronger with aluminium brackets that anyone with a pillar drill and hand tools can make, then this might the one for you!
Iv had a box prusa i3 for about 3 years now and my issue with it is the axis's are way to flimsy, mainly due to the use of 8mm steel rods for the linear motion. Also its not exactly house friendly as it pretty big, noisy, and the bed level gets thrown off eveytime it moved.
So I set about trying to find a new design that would fix these issues, and meet the list of requirement below,
Small foot print. This printer will hopefully live in the house, unlike my current printer which lives in the garage, so id like it to have a relatively small foot print.
Direct Linear motion Iv played with a delta bot before, and I found calibrating the non linear motion system and getting the bed level a bit of a nightmare. I know it can be done, but its not for me.
Quite Again been in the house id like it to be nice and quite.
20x20 V slot linear rails Iv got about 8m of the stuff loads laying around so its time to use it!
Mini V Wheels Again iv got a bag full in the garage so time to use them!
Portable Its likely the printer will like in our spare bedroom so it might need to be moved when we have guests
Mega rigid In my opinion rigidity of the frame and motion systems is crucial to achieving good print quality, and is often over look with most reprap printers. To achieve this I plan on making all structural parts from 5mm thick aluminium sheet, but only using hand tools and a pillar drill.
KISS Keep It Simple Stupid. Simple is best, why add complexity when its not needed. Simple means it easy to design, easy build, easy to modify ...
The first couple of points on that list essentially dictate a fix or Z only build plate, and the X and Y axis been on the extrude. (Im sure theres a name for this type of design, but you all know what i mean!)
So i set about looking for design that met these requirements, but nothing jumped out at me, so i decided to design my own. After all I find it much more fun designing and making my own designs, so why not!
I settled on Core XY style motion as i like the idea of stationary motors, and i can enclose the sides of the machine with aluminium or polycarbonate sheets to make it super rigid. Also all the electronics can be safely and neatly hidden away inside the frame.
So this is the design so far.
postimg.org]
postimg.org]
postimg.org]
postimg.org]
Couple of things worth point out.
Firstly this is far from the finished product, epically the Z platform and overall frame dimensions.
In the images the frame is currently 500 by 500mm, but once i am happy with the design i will reduce this down to fit a print area 200 x 200mm, im not sure about the height yet.
The X and Y carriage are all made from double sided aluminium plate to improve stiffness. The Z carriages are single sided. I chose single sided for the Z axis so i can easily enclose the back and sides, improving the overall frame stiffness, and the lateral load on the Z platform should be very small anyway so there is no need for double sided carriage hear anyway.
The current Z platform design uses 3 guides and 3 m5 threaded rods all driven from one stepper motor. I really don’t like the look the canter leaver beds, so three guides and screws was a minimum. I was tempted to change this to 4 but that would make enclosing the back a little more difficult. The choice of threaded rods over lead screws might surprise, but assuming the Z platform is sufficiently stiff in the lateral direction to prevent any Z wobble due to not perfectly strait screws, i see no reason why i should splash out on lead screws. Also if they are good enough for the E3D big box, they are good enough for me!
For the build platform I currently plan on using a sheet of ecocast aluminium from aluminium warehouse. The benefits of this are i can fix it directly to the z platform frame, and there should be no levelling problems like you get when you remove and replace a glass bed. I plan on simply sticking a standard 12V heated bed to the underside of the aluminium.
Any comments and questions are greatly appreciated, I’d really like to input of the reprap community!
I will keep updating this thread during the design and build. Im going to print all the parts and assemble the printer first before cutting any metal.
Edited 1 time(s). Last edit at 05/10/2016 03:00PM by Andy1989.
