Re: Z axis not homing correctly - PLEASE HELP -- [SOLVED] May 18, 2016 01:22AM |
gforce1
I have watched your video and i think the speed for non printing moves is to high.
What are your settings in your slicer? Set them at app. 30 mm/ sec if it works you can try raising them step by step.
Re: Z axis not homing correctly - PLEASE HELP May 18, 2016 04:26PM |
Re: Z axis not homing correctly - PLEASE HELP May 19, 2016 06:15AM |
Re: Z axis not homing correctly - PLEASE HELP May 19, 2016 08:32AM |
gforce1
Are you printing from sd?
Turn the poti on the stepper (x-axis) a little bit clockwise.
Have you still got the problem with homing the z-axis? If So set the retract while homing to 5 mm instead of 2 mm
in CONFIGURATION_ADV_H
//homing hits the endstop, then retracts by this distance, before it tries to slowly bump again:
#define X_HOME_RETRACT_MM 5
#define Y_HOME_RETRACT_MM 5
#define Z_HOME_RETRACT_MM 2 --> 5
It will hit the endstop fast then goes up for 5 mm en then hits the endstop slow.
2 mm could be to less for resetting (switch it open again) the endstop.
Re: Z axis not homing correctly - PLEASE HELP May 19, 2016 11:53AM |
Re: Z axis not homing correctly - PLEASE HELP May 20, 2016 02:57PM |
Z axis not homing correctly - PLEASE HELP [SOLVED] June 12, 2016 06:56PM |
