Marlin error > echo: SD init fail
Posted by engmaster
May 11, 2016 05:06PM
Hello.
Today, I enable the "#define SDSUPPORT" to work stand alone from my pc.. but started my problem.
The SD Card work perfectly when insert or remove the card.. but when I start the printer without SD card the error appears in console of pronterface
echo: PID settings:
echo:  M301 P17.44 I1.15 D66.00 C100.00 L20
echo: Filament settings: Disabled
echo:  M200 D3.00
echo:  M200 D0
echo: SD init fail
I tryed change the LCD (same model) and problem persist.
How I fix it? Or it is normal when we dont have SD Card inserted?
I use the REPRAP_DISCOUNT_SMART_CONTROLLER
Thank you.
Edited 2 time(s). Last edit at 05/11/2016 05:35PM by engmaster.
Re: Marlin error > echo: SD init fail
May 11, 2016 07:17PM
Normal when there is no sd card.
June 30, 2016 11:51PM
I don't think this is normal behavior. Info screen shows when 'Card inserted' and 'Card removed' so that part is recognized. But once you go to the Main menu, the last menu item says No Card.
July 01, 2016 12:03AM
Tried many SD cards 512M, 4/8/16/32GB. The 16GB did not work at first. Once I tried an 8GB, most of the rest of the SD cards worked.
Edited 1 time(s). Last edit at 07/01/2016 12:06AM by iknownothing.
