Re: My Prusa MGN June 15, 2016 06:00PM |
Re: My Prusa MGN June 15, 2016 11:59PM |
Re: My Prusa MGN June 16, 2016 01:24AM |
Re: My Prusa MGN June 16, 2016 05:04AM |
Re: My Prusa MGN June 16, 2016 02:27PM |
Re: My Prusa MGN June 16, 2016 04:01PM |
Re: My Prusa MGN June 16, 2016 04:42PM |
Re: My Prusa MGN June 17, 2016 01:48AM |
Re: My Prusa MGN June 18, 2016 05:50AM |
Re: My Prusa MGN June 18, 2016 03:10PM |
Re: My Prusa MGN June 18, 2016 04:01PM |
Re: My Prusa MGN June 20, 2016 03:06PM |
Re: My Prusa MGN June 20, 2016 03:25PM |
bme
I like to test things. When something works I have difficult to change it.
Ramps 1.4, Atmega2560 or DRV8825 allways works in my case. No problem as you described.
I can have up 300 mm/sec speed, high acceleration and everithing with 32 micro stepping.
Tell me advantages with your own or others motherboards?
What can you do more then me with my electronic?
Re: My Prusa MGN June 20, 2016 05:02PM |
Re: My Prusa MGN June 21, 2016 04:42AM |
Re: My Prusa MGN June 21, 2016 02:08PM |
Re: My Prusa MGN June 22, 2016 05:28AM |
sigxcpu
300mm/s are reachable, if ever, on long, straight lines only. Even then, at 80 steps/mm which is the usual configuration it means 24000 steps/sec.
Base on this page (http://reprap.org/wiki/Step_rates) an 8-bit CPU will reach <10k steps/sec in total
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: My Prusa MGN June 23, 2016 04:43AM |
Re: My Prusa MGN June 23, 2016 06:15AM |
sigxcpu
- we (me?) are spoiled by graphical LCDs. I'm using Repetier firmware right now and I like the tons of information in the primary screen and the myriad of settings and menus without G-codes or re-uploading the firmware. Does Teacup have that?
- The config tool is cumbersome at least. Why don't you use the "normal", float, numbers format and transform them to integers right when you generate the configuration file? There is no need for an user to see the internal huge numbers representation because Teacup is using integers.
- are the usual G-code senders (PrintRun, Octoprint, Repetier Server/Host) compatible with Teacup? Can you emulate "marlin" or "repetier" like RepRapFirmware does?
Re: My Prusa MGN June 23, 2016 09:03AM |
Re: My Prusa MGN June 23, 2016 09:24AM |
sigxcpu
Having a way to tweak stuff after upload is good because it is cheaper in consumed time.
Re: My Prusa MGN June 23, 2016 02:14PM |
Re: My Prusa MGN June 23, 2016 02:28PM |
Re: My Prusa MGN June 23, 2016 02:33PM |
Re: My Prusa MGN June 23, 2016 02:35PM |
bme
@bme: again, sorry to hijack your thread.
No problem at all!
I work more with mechanical design like now some tests with 0.8 mm layer height.
It is very difficult to cool such amount of PLA.
[attachment 80277 CIMG2602.JPG]
Re: My Prusa MGN June 23, 2016 02:43PM |
Re: My Prusa MGN June 23, 2016 02:46PM |
Re: My Prusa MGN June 23, 2016 02:49PM |
bme
The nozzle is 1 mm in diameter. I drilled a hole in a 0.4 mm nozzle.
Not so big precision but it works for some tests.
[attachment 80278 nozzle.jpg]
Re: My Prusa MGN June 23, 2016 03:19PM |
Re: My Prusa MGN June 24, 2016 11:58AM |
