IWorkInPixels Wrote:
> Hi guys, my name's Tony... been wanting a Makerbot
> or RepRap for a while now, and can't afford one...
> so I was thinking I'd build a RepStrap so I could
> pay for materials in increments and learn
> something about how these things work in the
> process!
> Toward that end, I started building a McWire
> cartesian bot, but I don't think it's going to
> work with the motors I bought from eBay because
> they're too big and heavy (thought I was getting
> NEMA 17's... turns out they're NEMA 23's).
> Ebay link
> They also came with these boards which have a
> driver chip on them, but someone over at CNCZone
> told me that the chips are probably useless for my
> purposes because they don't do microstepping...
You don't need microstepping if you are using threaded rod as a leadscrew, you will have plenty of resolution. Reprap machines only need 0.1mm resolution. Milling machines need more but with a 200 step motor and a lead screw pitch of say 1mm for M6 studding that would give 5 um per step.
> So... here's where I'm at:
> I was thinking about making an Eiffel-like device,
> but it'd be a gantry with a fairly large,
> stationary build area underneath. That way when I
> get the thing up and running I can print a whole
> set (or maybe 2 or 3 sets!!!) of Mendel parts all
> in one go. Does anyone see problems with this
> plan?
Probably OK if you use PLA. If you ABS you would need a heated bed, which if it is large will need a lot of power. About 1kW per square meter just the maintain temp and several times that to warm up in a reasonable time.
> Also, it's much cheaper for me to try to build the
> thing with a leadscrew drive for the axes, but I'm
> told that I will have problems with them not being
> able to move as fast as the minimum speed of the
> extruder if I do that... can someone give me more
> info on that?
You will probably only get about 6mm/s which is very slow for a reprap machine. If you use a stepper based extruder you can extrude as slow as you want, but it will take a very long time to make anything. For example, a Mendel would take about 240 hours.
> Third, and finally... I need to drive these big
> honkin' motors now... will the RepRap Gen3
> motherboard be able to do so? Or some other
> easily obtainable off-the-shelf solution? Or am I
> stuck trying to cobble together some sort of
> custom gear?
The motherboard doesn't drive the motors directly so it can drive any size motors provided you have stepper drivers to match and they have step and direction inputs.
> Thanks! I hope to get this RepStrap up and
> running soon, use it to print out several sets of
> Mendel parts which I'll sell to recoup some of the
> cost of the machine, and then refit the machine to
> be a laser cutter or something and use my Mendel
> for printing.
> Oh, and one more thing... these things are rated
> for 149 - 179 oz in of torque depending on how you
> set them up, and the folks over at CNCZone said
> that's mighty weak if I want to ever set it up to
> do any milling... is that true? I mean, I wasn't
> planning on milling metal (YET), but it'd be nice
> if I could cut my own furniture parts out of 1/2"
> MDF on this thing...
That is typical torque from a NEMA23 and certainly enough to drive a fine pitch lead screw to do slow milling. Even with a large pitch leadscrew you will be able to mill wood and plastic but you will probably need more torque for metal.
www.hydraraptor.blogspot.com]
