Attaching silicone heater to borosilicate glass May 22, 2016 01:53PM |
Re: Attaching silicone heater to borosilicate glass May 22, 2016 02:00PM |
Re: Attaching silicone heater to borosilicate glass May 22, 2016 02:11PM |
Re: Attaching silicone heater to borosilicate glass May 22, 2016 02:21PM |
Re: Attaching silicone heater to borosilicate glass May 22, 2016 02:49PM |
Re: Attaching silicone heater to borosilicate glass May 22, 2016 04:59PM |
Re: Attaching silicone heater to borosilicate glass May 23, 2016 02:48PM |
Re: Attaching silicone heater to borosilicate glass May 23, 2016 04:59PM |
svenyonson
... I think the weight is not as much as an issue for yours since the Z doesn't go up and down like mine. I have two Nema 17s and ball bearing lead screws. Maybe I can upgrade those to Nema 23s if the weight is too much.
Re: Attaching silicone heater to borosilicate glass May 25, 2016 07:56AM |
Re: Attaching silicone heater to borosilicate glass May 25, 2016 03:44PM |
Re: Attaching silicone heater to borosilicate glass May 25, 2016 03:48PM |
Re: Attaching silicone heater to borosilicate glass May 25, 2016 04:10PM |
realthor
So why would glass backed by a silicone heater behave in such a way that we get the thermal images like d_d posted?
Re: Attaching silicone heater to borosilicate glass May 25, 2016 04:44PM |
dc42
Because silicone heaters don't heat very evenly
Re: Attaching silicone heater to borosilicate glass May 25, 2016 05:04PM |
realthor
dc42
Indeed that is a deal-breaker
Re: Attaching silicone heater to borosilicate glass May 25, 2016 05:47PM |
dc42
realthor
dc42
It's not a problem if you use an aluminum heat spreader between the heater and the glass. I'm not sure that PCB bed heaters are any better in general.
Re: Attaching silicone heater to borosilicate glass May 25, 2016 05:49PM |
Re: Attaching silicone heater to borosilicate glass May 25, 2016 05:56PM |
Re: Attaching silicone heater to borosilicate glass May 25, 2016 05:58PM |
amigob
i uses boro glass and 1.5 mm head spreader with silicon heater. it works very well.
But be care full aluminum will expand 2 times of the boro glass.
I used 10x10cm squares and used dubble side tape to stick these squares to the glass with 1mm spacing
This is to avoid deformation of the glass when the alluminium is expanding more then the boro glass
Re: Attaching silicone heater to borosilicate glass May 26, 2016 06:03PM |
Re: Attaching silicone heater to borosilicate glass May 26, 2016 06:17PM |
("P3steel DXL, with Due/RADDS/Raps128 dual Wade's extruder")|
Re: Attaching silicone heater to borosilicate glass May 26, 2016 06:20PM |
amigob
reading the other thread , glueing is not that smart. Use the double sided tap because it also creates a flexible connection,
I have no insulator underneath the heater, yet, and it takes 7min to 90c
Re: Attaching silicone heater to borosilicate glass May 26, 2016 06:25PM |
Re: Attaching silicone heater to borosilicate glass May 26, 2016 06:29PM |
Re: Attaching silicone heater to borosilicate glass May 26, 2016 06:46PM |
amigob
but there is also no direct contact between the heater and the aluminum.
Re: Attaching silicone heater to borosilicate glass May 27, 2016 02:24AM |
