e3d v6 help
Posted by koenejet
Re: e3d v6 help
June 12, 2016 08:54PM
Toranado looks super sexy, but I wonder if all that shrouding is limiting the airflow away from the e3d's heatsink?
Re: e3d v6 help
June 13, 2016 04:20PM
Well it's funny you should mention that. I have also been posting my problems on Thingiverse. Someone else has my same problem. The designer of the toranado replied back to us and wants us to remove that lower shroud and see if that helps.
Apperantly, he thought that could be an issue, but his worked fine.
So if removing the shroud works, then maybe he will design a new one.?
Re: e3d v6 help
June 15, 2016 05:36PM
Just an update. Someone else had the same problem as me, he fixed it by wrapping ceramic heat insulation around the hot end with kapton tape. I did the same, and it has been printing fine now for just over three hours. Hopefully this will hold up on longer prints as well. So I believe It's all fixed. Keep your fingers crossed.
Thinks again for all the suggestions.
