heat bed problems June 07, 2016 01:58PM |
Re: heat bed problems June 07, 2016 02:08PM |
Re: heat bed problems June 07, 2016 02:22PM |
Re: heat bed problems June 07, 2016 02:56PM |
Re: heat bed problems June 07, 2016 05:20PM |
blahhh10
This is silly, but output terminals would be D8 right ?
Re: heat bed problems June 09, 2016 07:03PM |
dc42
Measure the voltage at the PSU terminals which you say is 12V under load, the voltage on the electronics power input connector, the voltage at the bed heater output terminals of the electronics, and the voltage on the bed terminals which you say is 10.5V. From those measurements, work out where that 1.5V is being lost and take steps to reduce it. Also, add thermal insulation under the bed.
Re: heat bed problems June 09, 2016 07:21PM |
blahhh10
I am just building my first custom sourced printer and am having trouble with my mk3 alu dual heatbed. It takes forever to heat up past 90C and then plateaus at 102C. I need 110C for abs.
Re: heat bed problems June 09, 2016 08:10PM |
Re: heat bed problems June 09, 2016 09:24PM |
Re: heat bed problems June 11, 2016 10:09AM |
the_digital_dentist
blahhh10
Unless you print inside a warm enclosure you won't be able to do much with ABS anyway. If the bed isn't warm enough (105C), prints won't stick, and if the enclosure isn't warm enough (45-50C), prints will delaminate. You need both to print ABS reliably (and of course, a flat, level bed with the right covering).
Unless you spring for a silicone or kapton heater you'll probably continue to have problems heating up to ABS print temperatures. About 0.4 W/cm^2 areal power density (or more) seems to do the job in a reasonable amount of time.
Re: heat bed problems June 11, 2016 11:37AM |
Re: heat bed problems June 11, 2016 01:14PM |
Re: heat bed problems June 11, 2016 01:41PM |
Re: heat bed problems June 11, 2016 04:01PM |
blahhh10
I think I'm going to go with the heater mat you suggested. I found one at 0.7W/cm^2 but it is just 150mm x 150mm. My aluminium printbed is about 210*210mm. Do you think the 150mm one should be big enough or should I go with one that is 200 x 200 mm heater mat ?
Re: heat bed problems June 11, 2016 04:11PM |
the_digital_dentist
blahhh10
The heater should be about the same size as the bed plate, otherwise the temperature drop toward the edges will limit you to printing only in the area directly above the heater- your 210 x 210 bed will effectively become a 150 x 150 bed. That's OK if you don't mind it, but if you're expecting to use the whole bed you'll be sorry.
Select the bed heater that delivers the necessary heat first, then start selecting parts to switch power to it. Using a line operated heater can simplify things in terms of power supply and relay, but you have to be careful to wire it safely.
Low voltage heater:
AC operation- use a transformer and DC-AC SSR (no heatsink required). Controller board drives SSR, SSR switches power from transformer to heater.
DC operation: connect to printer power supply (if sufficient rated current) or separate DC supply. Use MOSFET on controller to switch power to bed if the MOSFET and PCB can handle the current, or use DC-DC SSR possibly mounted on a heatsink, depending on the SSR. Regulated power is not necessary for bed heater- a DIY power supply can consist of a transformer and bridge rectifier, but its easier/cheaper to just power the bed from the transformer.
Line voltage heater:
Use DC-AC SSR with no heatsink to switch AC line power to the heater. Ground printer frame, wire bed heater carefully to prevent possible shock hazard.
Re: heat bed problems June 11, 2016 04:20PM |
Re: heat bed problems June 11, 2016 04:23PM |
the_digital_dentist
It should work, but you may need a heatsink on the SSR depending on its internals. You'll need some pretty heavy cable to connect to the bed heater. Since you're using a separate supply, using 24V instead of 12 would reduce the required current and allow smaller, more manageable cable to be used.
Re: heat bed problems June 11, 2016 04:38PM |
Re: heat bed problems June 11, 2016 05:48PM |
Re: heat bed problems June 11, 2016 09:43PM |
Re: heat bed problems June 11, 2016 09:48PM |
Re: heat bed problems June 11, 2016 11:44PM |
the_digital_dentist
About that bed... Are you going to be using tooling plate or a thin piece of aluminum with a glass plate, or something else? I recommend 1/4" cast tooling plate. It is rigid and flat enough to print on with just a layer of kapton tape- no glass needed. Thin plates are extruded and never flat, and will bend, especially if you have a 4 point leveling system.
Do you have a 3 point or 4 point leveling system? I recommend 3 points- 4 point systems bend the bed plate and undercarriage. 3 points actually level the plate (assuming you have a flat bed plate).
Re: heat bed problems June 12, 2016 07:07AM |
Re: heat bed problems June 12, 2016 10:15AM |
the_digital_dentist
Before you glue the heater to it, check the flatness of the bed plate. Set the edge of a steel ruler against it and see if there are any gaps. 3 mm sheet isn't usually very flat, but since the bed is relatively small you may be OK.
24V 30A is over 600W, more than enough to run the 240W heater. Use the diagram provided by the relay seller and you should be good to go.
Re: heat bed problems June 12, 2016 10:30AM |
Re: heat bed problems June 12, 2016 10:55AM |
Re: heat bed problems June 12, 2016 11:53AM |
