Electronic for new BIG 3d Printer
Posted by ADRIANO3D
June 21, 2016 08:32AM
Hello guys,
i need your help about the electronics for my project.
Printer is this (300x300x250)
BIG 3D
Please help me about:
-BOARD
-MOTORS (2 NEMA 23 + 3 NEMA 17)
-EXTRUDER (only 1)
i wait your comment
thanks
Edited 1 time(s). Last edit at 06/21/2016 09:06AM by ADRIANO3D.
Re: Electronic for new BIG 3d Printer
June 21, 2016 12:51PM
Board: a Duet 085 [www.filastruder.com]
If you're not in a big hurry, a DuetWifi at [www.duet3d.com]
The above boards just require you to edit a text file to configure the firmware and have a web interface to control the printer.
For a hotend, get a Genuine E3DV6, [www.filastruder.com]
June 21, 2016 04:53PM
I would caution against the use of Nema 23 motors. They are not needed for a printer of that modest size, but they will cause more vibration, and unless you use a separate higher voltage power supply and expensive drivers, they will have a lower maximum travel speed because of their high inductance.
There is a thread about Nema 23 vs.17 in the Duet WiFi forum at www.duet3d.com, in which I went through the calculations.
June 22, 2016 02:53AM
I understand.
i will modify the 2 support from holes NEMA 23 to holes NEMA 17
thanks for your help !
