Ring Terminals for Extruder Components June 24, 2016 11:29PM |
Re: Ring Terminals for Extruder Components June 24, 2016 11:55PM |
Re: Ring Terminals for Extruder Components June 25, 2016 02:50PM |
Re: Ring Terminals for Extruder Components June 27, 2016 12:30PM |
There are specially made connectors specifically for thermocouples, as well as wire to extend them with. McMaster in the US has them, I'm sure other places as well. McMaster 3869K35 is a male connector for K type, they have a variety to suit.Quote
deckingman
As DD said or you could use a thicker wire gauge if you are worried. You might want to consider using thicker gauge wires for the stepper motors in any case. I believe that they are more likely to be affected by the resistance of long cables as they may draw in the order of a couple of amps.
As an alternative to thermistors and if you want more accurate temperature measurements, you could do what I'm doing and use 4 wire PT100s instead of thermistors. That may depend on the electronics you plan to use though. The Duet has daughter boards which support thermocouples and PT 100s. Thermocouples would not be an option as you can't really have joins in the cables other than the one cold junction at the tip.
