building my first printer, a few questions. July 03, 2016 10:14PM |
Re: building my first printer, a few questions. July 03, 2016 11:16PM |
Re: building my first printer, a few questions. July 03, 2016 11:43PM |
Re: building my first printer, a few questions. July 04, 2016 12:28AM |
Re: building my first printer, a few questions. July 04, 2016 12:42AM |
yes its going to be my first 3d printerQuote
cozmicray
First 3d Printer?
What is wrong with a kit?
You can hack around using kitchen utensils
and cut thru the kitchen table?
You can spend weeks getting parts and reordering the right parts.
Spent hours in the hardware store looking for the wrong parts.
and spend $1000 for a $300 printer
With limited build tools a kit is perfect?
or
get all the parts (a tested design, drawings, instructions) in a kit
spend time getting frustrated 3D printing
instead of using your time wondering
how to connect part A to part Z so they don't flop around?
Take a look at Folgertech FT-5
[folgertech.com]
or
Ordbot hadron
[www.buildlog.net]
[www.automationtechnologiesinc.com]
BTW it's Engineering
---- looks like your "linear stepper" is a stepper motor with a leadscrew shaft and leadnut
some research and a design scratched out some butcher paper would also help?
but you could build first then build again with a design and some drawings.
thank you for your very informative responseQuote
anvoice
1) Everything to connect them (corner connectors, plates, t-nuts, screws, etc.)
2) Yes there are. Belts move much faster unless you get a super-expensive lead screw with a large mm/turn ratio. Even then, you'll have a hard time making a rigid h-bot with lead screws.
3) Nope, ebay's been pretty good to me. Watch seller feedback, get a few extra of things like stepper drivers for Ramps for example.
4) No.
5) Motor dampeners reduce noise. May or may be the limiting factor in your printer's overall noise production. Up to you on how quiet you want the thing to be (I can't sleep with mine going, no dampeners).
6) Some good lubricant for rods and threaded rods/lead screws, plastic, tape of your choice (depends on what you print with, but both blue painters tape and the Chinese Kapton clone work).
7) You can if you want to double the cost. I never did, only ordered replacements if needed.
That said,
You don't have to use a kit, but using a proven design like the Prusa i3 rework (what I have) for your first build is a definite plus. Once you have the hang of it, you can think about doing your own design (also when you have the tools). I am personally building a printer out of aluminum extrusion right now, but I've hung out a lot with my Prusa before going there. Plus I do have the required tools: angle grinder, miter saw, etc. I would NOT recommend doing a 2020 build right off the bat with no experience.
Re: building my first printer, a few questions. July 04, 2016 12:47AM |
Re: building my first printer, a few questions. July 04, 2016 01:04AM |
Re: building my first printer, a few questions. July 04, 2016 01:25AM |
Re: building my first printer, a few questions. July 04, 2016 10:42AM |
cozmicray
First 3d Printer?
Re: building my first printer, a few questions. July 04, 2016 10:44AM |
Overlord_Laharl
1 final question
in the i3 rework am i correct in assuming the threaded rods are just for the frame, and dont serve any other purpose.
Re: building my first printer, a few questions. July 04, 2016 12:23PM |
Overlord_Laharl
1 more question
i live in the USA, so am i able to configure the firmware to use a SAE threaded lead screw, instead of a metric sized one
if i am, then what threading is comparable to a m5
Re: building my first printer, a few questions. July 04, 2016 02:05PM |
i know the definations, i do hack PSPs and PS3s, and i was just using firmware in that sence, as "system software" or "operating system"Quote
cozmicray
My humble apologies Overlord
Firmware --permanent software programmed into a read-only memory.
Hardware --- nuts and bolts (never saw a "firmware" section in Home Depot or Ace)
Next to the SAE section is the metric section of nuts and bolts
Most settings on 3D printers are mm (mm/step etc)
2020 20mm x 20mm
25.2 mm per inch
You can do everything in english SAE --- soon you will see most is done in Metric
motor shafts and bolt holes metric, Belts and pulleys metric
the filament is 1.75 / 3 mm ---- I guess you can get SAE filament made up?
but you can search for and order up SAE parts
You can use slotted / philips head bolts --- or nice socket head (allen) bolts that you can tighten down well.
for rotation to linear motion (Z-Axis) threaded rod -- bad acme leadscrew --- better
But your the expert --- this is your first printer --- and you know it all because your a DIYer
you can trial and error all you want -- waste time and money
--- crayon and brown paper cheap --- design
---- CAD or simple draw app on your computer better
M5 (5mm thread diameter .8 course .5 fine thread per mm)
SAE close #10 fine ?? 1/4 - 32
but for tension rods an expert like you probably just use 1/4 -20
Re: building my first printer, a few questions. July 05, 2016 01:40PM |
Re: building my first printer, a few questions. July 05, 2016 04:13PM |
When making printer silent which is the next task after it prints, those are useful parts. Before I put 2mm cork to every motor, I could print only when the printer was on the floor. After dampeners I was able to put it on my workbench. I have P3Steel which likes to as one monolithic piece of metal now that it has nyloc nuts and the noise which it makes when it vibrates is awful loud.Quote
Lymphomaniac1
< 5) should i use motor dampeners or would that be unnecessary>
If you are referring to cork pads that one puts between the motor and the frame, they are totally unnecessary if you have a sturdy frame. Very few people use them and most people get good results without them. I actually bought some, but never got a chance to put them on my printers.
