I'm looking for a good connector to use for 220v 500w.
It needs to be 4 ping and male + female. Where one of them can be panel mounted.
Should be fairly easy to connect / disconnect and small.
Make sure you get the right version, i.e. panel-mounted plug for a mains inlet, or panel mounted socket for an outlet. The panel mount plugs and sockets are available with built-in switches, fuses and indicator lights.
Edited 2 time(s). Last edit at 08/30/2016 05:16PM by dc42.
