I'm pretty sure I'm going to die because of how good this print turned out. August 29, 2016 05:36PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 30, 2016 01:08PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 30, 2016 02:47PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 30, 2016 03:51PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 30, 2016 04:09PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 30, 2016 07:18PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 31, 2016 01:48AM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 31, 2016 02:17AM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 31, 2016 05:16AM |
n8bot
80 micron layers, e3d v6, PLA, duet 0.8.5, 400 micron nozzle, PEI print surface, 94 hour print time (looking to improve with the new printer/push this printer to the limits)
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 31, 2016 02:23PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. August 31, 2016 10:22PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 01, 2016 01:03AM |
Govahnator
I am impressed man, good job!
What do you have in mind for your cartesian that would make it better then your Delta?
I am currently finishing my custom mendelmax 1.5 , need to take a new photo though, its no longer up to date.
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 01, 2016 01:35AM |
n8bot
Govahnator
Thank you! The main things for the new cartesian are: increased rigidity, increased resolution, linear resolution (vs the dynamic resolution of a delta), better components.
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 01, 2016 02:36AM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 01, 2016 03:33AM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 01, 2016 12:26PM |
deckingman
Just out of curiosity, what size is the print? Is it 1:1 scale? Also, what size are the stl and gcode files?
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 14, 2016 03:12PM |
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 14, 2016 03:27PM |
JamesK
Holy expletive! I pulled up the image full res and I can barely see the layers. The pores in the skin on the other hand are well defined. I wouldn't have recognized that as fdm, nor have believed it was possible. Was there any surface finishing post-print?
Re: I'm pretty sure I'm going to die because of how good this print turned out. September 16, 2016 09:51AM |
