Print extrudes but no XYZ motion
October 14, 2016 09:58AM
Finally all axis's and endstops are working properly in Marlin and
home correctly with m-code in RepetierHost.
Printing the first part the printer homes and heaters heat, but none of the axis
ever move, except the extruder and it's extruding as if it were printing.?
Using repetier-host, marlin, ramps1.4 w/2560 on a solidoodle2 frame.
This is my first (re)build.
Thanks in advance.
Edited 1 time(s). Last edit at 10/14/2016 03:51PM by instmkr.
Re: Print extrudes but no XYZ motion
October 15, 2016 01:20AM
Do you mean that they move when manualy told to?
check max feed rates
Edited 1 time(s). Last edit at 10/15/2016 01:21AM by Dust.
October 15, 2016 11:46AM
> "Do you mean that they move when manualy told to?"
Yes, full control manually in rHost, and marlin via display/control.. Can drive all axis into their endstops, it stops movement. Drive the axis towards non-endstop end and software stops it just before crash.
Ramps test code does its thing in all axis. Only running the initial/test print gives the unexpected result of extrusion but no XYZ cooperation.
> "check max feed rates"
where should I check, in RH or configuration.h?
My gut says all this is rookie mistake from fuzzy comprehension of the following;
home, origin, max/min, zero and the enstops relation to those terms in RH setup and configuration.h.
Thanks
October 15, 2016 09:23PM
max feed rates is in configuration.h
what I suspect is your just telling the axis to move to quickly when printing, vs the gui which uses a slower feed rate
convert a test cube to gcode, and take a look at the gcode, first 20 lines are probably enough, look for G1 command that have a X or Y parameter... this is a move
the F parameter either on the same line or a previous line sets the feed rate.
(paste your eg into pastebin.com and post a link here for examination)
also do a M503, and paste the output, in case it shows anything useful.
October 15, 2016 11:47PM
Max feedrate set to XY 150 in cofiguration.h, also at pastebin. Attachment is pic of repetierH printer settings
Thanks
[pastebin.com] gcode
[pastebin.com] M503
[pastebin.com] configuration.h
open | download - 1test repetier settings.jpg (174.4 KB)
October 16, 2016 11:54AM
What positions do you have your end stop switches ?
In your config.h you have them set for x,y,z - max
383.// @section homing
384.
385.// Specify here all the endstop connectors that are connected to any endstop or probe.
386.// Almost all printers will be using one per axis. Probes will use one or more of the
387.// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
388.//#define USE_XMIN_PLUG
389.//#define USE_YMIN_PLUG
390.//#define USE_ZMIN_PLUG
391.#define USE_XMAX_PLUG // <<<
392.#define USE_YMAX_PLUG // <<<
393.#define USE_ZMAX_PLUG <<<
but in Rep host you have them set to min.
would this cause a conflict ?
October 16, 2016 01:50PM
>"What positions do you have your end stop switches ?"
Facing the printer's front, endstops are located at X right, Y back, Z top.
>"but in Rep host you have them set to min. would this cause a conflict ?"
Changed them back to MAX then zero but got same result. sigh
Attachment shows preview of layer 0 travel (odd yes?). That start position is opposite the XY endstop positions.
Thanks
open | download - start travel.jpg (171 KB)
October 17, 2016 05:12PM
It was something to do with Z homing or min/max.
Many thanks for assistance.
