Just wanted to say Hi. October 15, 2016 06:15AM |
Re: Just wanted to say Hi. October 15, 2016 10:22AM |
Re: Just wanted to say Hi. October 15, 2016 12:57PM |
Re: Just wanted to say Hi. October 15, 2016 03:52PM |
Rlewisrlou666
Thanks for the reply JamesK
I have a sheet of 1.5mm Aluminium that I've been saving for a project. I'm was thinking of using that as a bed with a coating on it.
Re: Just wanted to say Hi. October 15, 2016 05:30PM |
1/4" tooling plate looks very good for the standard 200mm2 bed, and I think it would probably be ok at 400mm, but it's possible you might need to go to 3/8". It gets very expensive unless you have a local metal supplier that you can pick up from (or if you are in the USA where shipping prices are often much more reasonable than most of the rest of the world). I'm trying to convince myself to pay up for tooling plate for my next printer, but I want to see the rest of it working first.
Re: Just wanted to say Hi. October 15, 2016 07:14PM |
Re: Just wanted to say Hi. October 15, 2016 07:57PM |
Personally I'd like to see it done, because I'm pretty sure it's possible, but you should be aware that it's definitely a case of doing it the hard way, and might turn out to be impractical. So what sort of issues might you run into? If the heater is on the bottom of the composite the bottom layer of aluminum will get hotter before the top pieces, especially with fibreglass (an insulator) in between them. The differential expansion will try and force the composite into a sphere unless you allow for the layers to move independently. Similarly, the coefficient of expansion of the aluminum and fibreglass layers is likely to be different, so even at a constant temperature those will try and warp unless they can move separately. Level is not the same as flat, and the requirement for flatness is quite severe if you want to use a small first layer. My current print surface is very non-flat, so I compromise with a thick first layer which is severely squished over parts of the build. Even so I struggle with full plate parts - first layer adhesion is critically dependent on the Z=0 height from the bed. That said, some firmwares have started to incorporate bed mapping and compensation for non-flatness, but I don't know how well it works. In general, a lot of people have problems getting even basic leveling correction working reliably, and even if it works it means that the Z axis has to continually operate in non-full step increments - that's not a recipe for accurate layer extrusion. This is one of those cases where doing it right is definitely doing it better. (But, I also want to try auto bed leveling one day to see just how well it works for myself. What can I say, I suffer from excessive curiosity.)|
Re: Just wanted to say Hi. October 15, 2016 07:58PM |
Re: Just wanted to say Hi. October 16, 2016 03:09AM |
Re: Just wanted to say Hi. October 16, 2016 07:08AM |
If I have to build a thicker more solid Build Platform then so be it but it doesn't mean I can't have a bit of fun playing around before I get to that point.
I did briefly think about making a sandwich with the peltiers in between two layers of Al, but that's asking for the heat bed to banana as one side heats and the other cools. Plus, I suspect that uneven heating of the surface is likely to be an issue, so having all the aluminum on the top side seems like the right approach. I've made a quick test rig with four peltiers on a 200mm2 plate and it heats up ok. Haven't checked the cooling aspect yet, but since that's less critical than heating I don't expect any problems. Heatsinks and fans on the underside of the peltiers will disperse the heat.
Re: Just wanted to say Hi. October 16, 2016 09:44AM |
Re: Just wanted to say Hi. October 16, 2016 10:03AM |
Rlewisrlou666
Thank you for the advice guys I'll ask my Brother In Law what sheet metals they do at his place.
@dougal1957 - Would I be able to run a heater of that wattage through an SSR to make it more usable without the need for a 1000w Power Supply?
Re: Just wanted to say Hi. October 16, 2016 02:43PM |
Re: Just wanted to say Hi. October 16, 2016 06:11PM |
Re: Just wanted to say Hi. October 16, 2016 06:42PM |
elwood127
Check this site. You may be surprised how cheap it would be to go extruded frame.
[www.adafruit.com]
Re: Just wanted to say Hi. October 16, 2016 06:47PM |
Re: Just wanted to say Hi. October 17, 2016 10:30AM |
Rlewisrlou666
Thanks for the link elwood127 I'm in the UK though.![]()
Re: Just wanted to say Hi. October 17, 2016 10:52AM |
Re: Just wanted to say Hi. October 17, 2016 11:19AM |
Rlewisrlou666
@Doug - I'm in Chepstow,
I found a PCB supplier that will sell me some copper clad in the size I need I just have to design something to etch onto it or find someone who knows how to work eagle that can help me design a Gerber file to send to them for a price on making the heater for me.
Re: Just wanted to say Hi. October 17, 2016 12:05PM |
Re: Just wanted to say Hi. October 17, 2016 01:19PM |
Re: Just wanted to say Hi. October 17, 2016 01:43PM |
JamesK
I just ordered another RAMPS based electronics package. You can't beat the value at around 30 USD including the graphical LCD (so thats mega2560, ramps, 5xdrv8825 and the LCD). Duet wifi looks like the outright best designed controller card to me, but I find the price intimidating in the short term. There's no doubt that 32bit is the way to go in terms of ease of use and increased ceiling for high step rates. I have been wondering about getting one of ST's 32 bit evaluation boards which are very reasonably priced and adding my own interfaces to stepper drivers and mosfets. But realistically it would be a lot of work to get up and running and I have too many pipe-dreams already in the queue. This weekend I modified a spare RAMPS to remove D1 (that sends the 12V input to the mega2560 Vin) and set it up with a new PSU running at 13V with a boost converter to produce 7.5V from the 3.3V stand-by for the mega. Works a treat. With this setup I may opt for a 25V supply in the next build.
Re: Just wanted to say Hi. October 17, 2016 02:04PM |
Re: Just wanted to say Hi. October 17, 2016 02:17PM |
Re: Just wanted to say Hi. October 17, 2016 02:22PM |
Rlewisrlou666
I couldn't find any Duets for that cheap.
I was looking at the RADDS but they need an Arduino Due so £40 for the RADDS + £25 for the Due and you are looking at £65 plus the extras on top of that drivers and everything else.
Re: Just wanted to say Hi. October 17, 2016 02:26PM |
Re: Just wanted to say Hi. October 17, 2016 02:38PM |
dc42
T3P3 still sells Duet 0.6 boards as well as the 0.8.5 and WiFi. See [www.think3dprint3d.com].
Re: Just wanted to say Hi. October 17, 2016 03:38PM |
Re: Just wanted to say Hi. October 18, 2016 02:59AM |
Re: Just wanted to say Hi. October 18, 2016 03:18AM |
