European source of cast aluminum tooling plate October 17, 2016 06:59AM |
Re: European source of cast aluminum tooling plate October 17, 2016 10:45AM |
Re: European source of cast aluminum tooling plate October 20, 2016 05:44AM |
dougal1957
see [www.aluminiumwarehouse.co.uk] in particular point 4 which suggests that they will ship outside the UK but that you may be liable for import taxes.
Certainly dropping them an Email to check?
Doug
Re: European source of cast aluminum tooling plate October 20, 2016 06:22AM |
Re: European source of cast aluminum tooling plate October 21, 2016 04:48PM |
Re: European source of cast aluminum tooling plate October 21, 2016 05:12PM |
JTa
If you need it for heated bed I recommend this: [clever3d.de]
They make PEI coated plates. I got 2 custom sized plates from them for my printers and they work just perfectly. Plates are flat and ABS/PLA/PETG stick like ever before and when the bed cools down the parts just float of. No more hassle with glues or tapes or hairsprays or whatnot.
Re: European source of cast aluminum tooling plate October 25, 2016 06:45AM |
JTa
Re: European source of cast aluminum tooling plate November 02, 2016 09:07AM |
Re: European source of cast aluminum tooling plate November 02, 2016 09:15AM |
Amoniak
With the PEI, both sides are coated. Are they using some kind of "dip" method to apply the PEI?
Re: European source of cast aluminum tooling plate November 14, 2016 05:49AM |
Re: European source of cast aluminum tooling plate March 10, 2021 03:44AM |
