Kossel mini auto leveling
Posted by waelajam
October 25, 2016 04:56PM
Hi everyone
I am facing a problem with the auto-leveling of my kossel mini 3d printer.
Right now I am trying to calibrate it by Pronterface but in vain sad smiley
Please has anyone a detailed instructions or preferably a video that explains the steps thouroughly and clearly.
Please have a look at the problen in this video. It happened when sending G29 in Pronterface
[drive.google.com]
Thanks´╗┐
Edited 1 time(s). Last edit at 10/25/2016 05:01PM by waelajam.
Re: Kossel mini auto leveling
October 28, 2016 03:18PM
This might be a better question for the delta forums.
I have moved on from Marlin / RAMPS boards for my delta, but at the time I recall G29 being for cartesian bed leveling not delta auto-calibration. I would consider reviewing the firmware for your printer to make sure you are using the correct g-code and parameters. You also will want to make sure the printer is dialed in a closely as possible before running the auto-calibration routine for the final tweaks.
Finally, what firmware are you using and consider attaching your config.h file so that others might be able to offer some assistance.
October 28, 2016 04:14PM
Hi
I could eventually diagnose the problem. It was the broken Z probe switch which is responsible for this disorder. There was a delay between the open status and the triggerred and sometimes it yields only triggerred.
Edited 1 time(s). Last edit at 10/28/2016 04:16PM by waelajam.
