This might work for you,
This fan duct and spacer with a 75mm x 30mm blower fan [
www.thingiverse.com]
There is a fan spacer used upon the Ormerod 2, which sits between fan and heat sink, upon which the ormerod fan duct is mounted.
It mounts the fan in the X-axis direction, so looking at you photos it would point out to the right hand side, looking from the front.
So it looks like this
You will need to design a mounting bracket. As you can see in the photo above. It's the white long arm
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
