Is it posible to print only part of an stl file at 100%
Posted by gregted
December 31, 2016 11:49AM
I want to print a part but only want the area around the holes to be 100% and the rest of the model at 50%.
I want to do this because at 50%, when I tighten the bolts down, they crush the pla.
If the area immediately around the bolt holes was 100%, all would be good.
I have tried to break the file down to parts and align them on cura but cura won't let me have parts touching and moves them apart.
Any ideas??
Re: Is it posible to print only part of an stl file at 100%
December 31, 2016 01:47PM
Usually you slice an object with 2-4 perimeters, but if you want extra strength around holes, you can use more perimeters and top/bottom layers. Then leave the infill to 50% and save time and filament.
December 31, 2016 03:28PM
Slic3r has a feature called load modifiers, IIRC. This allows you to set different parameters in specified areas.
December 31, 2016 04:09PM
Simplify can do it as well, but the part that needs to be treated differently has to be an own object.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
January 01, 2017 06:22AM
Load all the parts in Cura, then right click on one of them and choose: Combine parts for multi-extruders
That will automatically place them together.
