Hi there!
I have a weird issue that I hoped someone may shed some light on!
I am trying to calibrate my extruder, at the factory firmware setting (320 or something) it shot out about 320mm of ABS, so I adjusted it to the calculated ratio (I only wanted 100mm). The problem was it seems to have very little affect on the output.
I request 100mm of cable and still get around 300mm of 1.7mm outputting, even with a resolution of 10 steps/mm.
Does this make any sense to anyone?
I am using repetier firmware and host, RAMPS 1.4 with A4988 drivers. Microstepping 1/16. 11mm hob directly driven by stepper, feeding to a bowden tube. I have tried a new driver. I have tried regenerating the firmware from Repetier, and even manually entering the value into Arduino IDE (successfully)
Thank you again for everything.
Kevin
