Need a new j-hotend
January 12, 2017 07:29PM
Hello,
I am looking for a new j-hotend that already has the heating elements installed for my RepRap I2. I want to print 1.75mm PLA so I will probably something with a nozzle diameter between 0.3mm and 0.4mm. I was looking at this one, [www.lulzbot.com], but it seems to be for 3.0mm filament however when I contacted the company they said it has been done successfully before but it may not be as reliable as when using 3.0 filament. I don't know why that would be.
If you could provide links j-hotends available for purchase that you would recommend, that would be great.
Thanks.
Re: Need a new j-hotend
January 12, 2017 07:58PM
I have been using the hexagon hotend on my Prusa i3 builds. Comes in 1.75mm and .4 nozzle
In Canada:
[www.marginallyclever.com]
or:
[www.reprapdiscount.com]
Probably available in many other places
My updated Instructable on our Prusa i3 Build
[www.instructables.com]
January 12, 2017 08:41PM
Thanks for the suggestions. I see that they are sold out of the first product that you linked. However, like I said, I am ideally looking for a product that is already assembled. If anyone has any other suggestions I'd love to check them out.
January 13, 2017 08:09AM
E3D V6 all the way
E3D V6 fully assembled
January 15, 2017 02:09PM
SteveRoy
How?
Mine just clogs up and jams all the time.
What PLA and what setting do you use?
January 15, 2017 08:33PM
I have a 40mm fan blowing across the fins.
I use MG Chemicals or filaments.ca PLA. Temp at 185c usually, sometimes 190c.
With the hackspace i3 I built there have been 2 clogs/jams in about 2 years.
With my new build I did have to re-tighten the throat to nozzle as PLA was leaking from it. Seems OK after that.
I also clean the slots/grooves in the hobbed bolt on a regular basis as I find the 1.75mm filament tends to build up in it more than the 3mm hobbed bolt in my old setup - the hobbing is a lot finer than the old 3mm hobbed bolt. I just use the end of my tweezers to clean out the slots.
Steve
January 28, 2017 08:09PM
Prometheus V2. Stainless nozzle, short body. Has been awesome.
