Work in progress - new build taking shape January 16, 2017 08:46AM |
It's going to be coreXY initially, but I have a plan B to fall back to a more conventional Cartesian layout, in which case I would likely go with dual X carriages on that long X rail. Biggest concern at the moment is whether the single cantilevered support is viable for the bed size. I suspect it is an over-reach (literally and figuratively) but I wanted to give it a go as it makes ideal use of the parts I was given. The entire Z axis module (which is just rested roughly in place at the moment) is mostly unchanged from it's original configuration. I just had to remount the rail onto the base.|
Re: Work in progress - new build taking shape January 16, 2017 12:52PM |
Re: Work in progress - new build taking shape January 16, 2017 01:12PM |
