Y-Motor Stopped Working - Buzzes and is Locked Up
Posted by greg_michigan
January 19, 2017 12:31AM
I have a Prusa i3 purchased on eBay as a kit. The part I was printing finished successfully, but as soon as it finished, the stepper motor started buzzing very loudly. I tried to home all the axis and the y-axis still wouldn't move and was making the loud buzzing (x,z ok). I turned off the machine, and the motor is completely locked up. I don't see anything external impeding the motor or the belt, it just seized. Any ideas what happened? Not sure why the print was 100% successful and then that happened. This is only my second day using the machine.
Re: Y-Motor Stopped Working - Buzzes and is Locked Up
January 19, 2017 01:47AM
Remove the Y belt, is the motor still stuck?
Manually try and move the bed with the belt off does it move or is it physically jammed?
January 20, 2017 12:07AM
make sure the lcd shows that steppers are disabled and you may need to adjust that stepper driver pot
