Gap between outer shell and inner portion March 06, 2017 08:29PM |
Re: Gap between outer shell and inner portion March 06, 2017 09:59PM |
Re: Gap between outer shell and inner portion March 07, 2017 07:27AM |
I don't believe it was using the infill speed setting as this print was only 2 layers thick, so it was instead using the top / bottom layer speed which is 30mm/s. I can certianly try slowing this down some more though and I can also reduce the X / Y accelerations to see if that helps. I'll also try the thickness change when I get back as well - I'd have hoped that Cura would be smart enough to round the wall thickness as appropriate, you never really know with this sort of things. I'll report back once I've given it a go anyway.Quote
scottybfg
Try slowing down your infill print speed, if the infill is printed too fast, it will not have enough time to bond to the outline perimeters. Start at say 60mm/s then work your way back up.
I dont use cura myself but seeing a shell wall thickness of 1mm makes me think this could be the issue, with a 0.4mm nozzle try a wall thickness of 0.8mm or 1.2mm and see if that changes the print.
Re: Gap between outer shell and inner portion March 07, 2017 10:55AM |
Re: Gap between outer shell and inner portion March 07, 2017 04:40PM |
M201 X3200 Y3200 Z128 E3200
M201 X1600 Y1600 Z64 E1600
Re: Gap between outer shell and inner portion March 07, 2017 07:56PM |
Re: Gap between outer shell and inner portion March 08, 2017 02:12AM |
Re: Gap between outer shell and inner portion March 08, 2017 05:04AM |
Re: Gap between outer shell and inner portion March 08, 2017 07:51AM |
I'm not sure the print I did shows nothing of value at all, but you're right - I should have split it up a bit more. As Cura supports different settings per instance, I could print a few at a time - Each with difference slicing settings. The part itself prints quite quickly, but most of the time is spent waiting for the bed to cool so that I can remove them.Quote
scottybfg
You changed too many parameters at the same time to get any useful information.
You should change one at a time to see what affect it had, now that the problem has shifted we know its something to do with cura or the acceleration.
Try a print changing the acceleration back to the old, if the print looks the same as #2 (shells not joined) then you know its something to do with the shell width as changing the acceleration had no affect
The infill overlap is set to the default, which from memory I believe is the nozzle width - 0.4mm. I'll confirm when I get home tonight and do a print with it changed.Quote
o_lampe
How did you set the infill overlapping percentage?
Have you tried to use a different slicer?
I can certainly try rotating the part and also try different positions. I'll try and get a better picture of the issue as well, the photograph I took is terrible - That's what I get for using black PLA and my phone's camera.Quote
Ed would
My first thought was infill overlapping percentage
But look at your other walls - they look ok.
I have seen Cura do this before - stopping the infill too short of a perimeter. Try rotating the .STL on the print bed.
Ed
Re: Gap between outer shell and inner portion March 08, 2017 05:43PM |
Re: Gap between outer shell and inner portion March 09, 2017 01:15AM |
Re: Gap between outer shell and inner portion March 09, 2017 05:04PM |
Re: Gap between outer shell and inner portion March 09, 2017 05:37PM |
Re: Gap between outer shell and inner portion March 09, 2017 05:46PM |
Re: Gap between outer shell and inner portion March 13, 2017 09:54AM |
Re: Gap between outer shell and inner portion March 13, 2017 10:32AM |
Re: Gap between outer shell and inner portion March 14, 2017 09:22PM |
