Printing temp versus adhension March 23, 2017 09:31AM |
Re: Printing temp versus adhension March 23, 2017 09:51AM |
Re: Printing temp versus adhension March 23, 2017 10:15AM |
the_digital_dentist
I set the bed for 105C for the first layer and drops to 90C for remaining layers. The printer has a cast aluminum bed with a 1.5 mm layer of PEI on the surface. First layer print speed is usually 25-30 mm/sec. The hot-end is usually set to 240C for the first layer and 230 or 235 for remaining layers.
Re: Printing temp versus adhension March 23, 2017 12:35PM |
Re: Printing temp versus adhension March 23, 2017 01:02PM |
Ok, good info. I just had a go doing 215 C . Same fail ....Quote
the_digital_dentist
Heat and low speed usually do the job, but don't leave it too hot for the remaining layers or you'll have elephant footing.
Re: Printing temp versus adhension March 23, 2017 01:09PM |
Re: Printing temp versus adhension March 23, 2017 01:25PM |
Floyd
That sounds too cold for ABS. I print my ABS at 240c mainly. Heck even my PLA I run at 214c
Re: Printing temp versus adhension March 23, 2017 01:56PM |
Re: Printing temp versus adhension March 23, 2017 01:57PM |
Re: Printing temp versus adhension March 23, 2017 03:35PM |
Re: Printing temp versus adhension March 23, 2017 06:03PM |
etfrench
Is your printer enclosed?
Re: Printing temp versus adhension March 23, 2017 06:11PM |
Re: Printing temp versus adhension March 25, 2017 04:38PM |
Re: Printing temp versus adhension March 25, 2017 07:56PM |
Re: Printing temp versus adhension March 25, 2017 08:36PM |
Re: Printing temp versus adhension April 01, 2017 10:25AM |
Re: Printing temp versus adhension April 14, 2017 10:28AM |
the_digital_dentist
I'm pretty sure it was the bed under the glass that was bent. I'll bet the bed has 4 leveling screws...
Re: Printing temp versus adhension April 14, 2017 02:30PM |
Ok thanks, that's good info. Make sense with 3 level screwsQuote
Evan
the_digital_dentist
I had this structure once, really sucks. Broke my heated bed support. Now i have 3 leveling screws in a equally sided triangular structure and no problems. Also solved the problems that i had to level each print. These days i rarely level my bed.
