X and Y axis rotates after hitting endstop.
March 24, 2017 02:40AM
Hello,
I am using Marlin v1 with RAMPS1.4 board.
When I Home X and Y axis, it homes correctly but after hitting endstop the X and Y axis moves very fast, and at fast acceleration.
Does anyone came across this issue?
Regards,
Prashant.
Re: X and Y axis rotates after hitting endstop.
March 26, 2017 03:55PM
Moves fast to where? To start the print? If so, you can slow down the non printing speed in the slicer.
March 27, 2017 02:54AM
Moves fast away from home..
Actually my HBP size is 300x300mm.
So x,y cordinate for Z xis home was calculating at X_max/2 and Y_max/2.
Bit it didn't worked..Then I made changes..
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2.0) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2.0) // Y point for Z homing when homing all axis (G28)
March 27, 2017 08:43AM
Ok so it's moving to do "safe Z homing", so yes again you need to reduce in firmware homing speed.
