Heated Build Chamber - Temperature Control April 02, 2017 06:03PM |
Re: Heated Build Chamber - Temperature Control April 02, 2017 11:36PM |
Re: Heated Build Chamber - Temperature Control April 03, 2017 06:34PM |
Re: Heated Build Chamber - Temperature Control April 14, 2017 10:21AM |
Re: Heated Build Chamber - Temperature Control April 15, 2017 02:21AM |
Re: Heated Build Chamber - Temperature Control April 17, 2017 07:02AM |
Re: Heated Build Chamber - Temperature Control May 11, 2017 04:28PM |
Re: Heated Build Chamber - Temperature Control May 12, 2017 04:47PM |
etfrench
I used rigid insulation on two sides of my delta. I'm still working on the design for the third side as I want the extruder outside the enclosure. Currently I'm just using a piece of plastic bag to cover the front. The temperature several inches above the print bed stays around 40C. I expect eliminating drafts is more beneficial than the temperature.
Re: Heated Build Chamber - Temperature Control May 18, 2017 01:28PM |
In any case the amount used is .4kg in a 400m3 shop. It's nice to know the toxicity, but given the volume of PIR and the volume of the shop, I don't think I'll worry about it too much.
