Slowed retraction speed after changing to 0.9 Degree Stepper April 11, 2017 02:43PM |
Re: Slowed retraction speed after changing to 0.9 Degree Stepper April 11, 2017 04:20PM |
Re: Slowed retraction speed after changing to 0.9 Degree Stepper April 12, 2017 06:57AM |
dc42
Why not work out what pulse rate your extruder is demanding?
Step rate = stes_per_mm * retraction_speed_in_mm_per_minute/60
Example: 3587 steps/mm * 3600mm/min speed / 60 = 209.241 KHz
I believe the default maximum pulse rate for Smoothieware is 100kHz, but you may be able to change that in the configuration.
Re: Slowed retraction speed after changing to 0.9 Degree Stepper April 12, 2017 08:35AM |
Re: Slowed retraction speed after changing to 0.9 Degree Stepper April 20, 2017 11:40AM |
